I am using the buck-converter circuit from Low side N-Mosfet buck converter as the base of my design. And I want to replace the diode with a P-channel MOSFET. I also want to drive both MOSFETs with an op-amp like the following circuit: enter image description here Considering the direction of the p-channel MOSFET and the way it going to be drived I am wondering if this circuit works?
Update
For the sake of simplicity let’s consider the second circuit where MOSFETs are getting driven separately (for example by a micro-controller). Does this buck convertor work? enter image description here
  • \$\begingroup\$ Q1 would have also need a pullup to base. and determine how hot both FETs get when they are both turned on during transition \$\endgroup\$ Commented Mar 14, 2021 at 9:06
  • \$\begingroup\$ A high speed half Bridge is what you want electronics.stackexchange.com/search?q=half-bridge+design \$\endgroup\$ Commented Mar 14, 2021 at 9:08
    \$\begingroup\$ Have you tried simulating it? A PMOS+NMOS as an output stage, tied like that, means its impossible to disable them both when needed (such as a short circuit protection). Best stick with some ready made ICs. \$\endgroup\$ Commented Mar 14, 2021 at 9:09
    \$\begingroup\$ Schematics on black background discussion. General consensus is that they are low quality and difficult to read. \$\endgroup\$
    Commented Mar 14, 2021 at 10:47
    \$\begingroup\$ The 1980s rang. Viewdraw wants its colour scheme back. \$\endgroup\$
    – user16324
    Commented Mar 14, 2021 at 12:51
If you separated the two transistors, you would solve the problem of not having both turned off in the case of a fault, but you would need two, separate drivers. Using a μC might solve that problem, but a dedicated IC is a much better alternative, and cheaper. Safer, too, since it has some built-in protections. Not only that, but you will still be using a PMOS together with an NMOS. And if you're going to use two drivers for two transistors, then you're better off choosing them to be NMOS (see the relevant link in the comments). As it is, the PMOS has an additional delay due to the PNP. Also, the input source has separated ground compared to the load (it doesn't matter that you grounded the load, the source is floating).
Overall, it looks like you're stuck on this particular design, for some reason. I wouldn't recommend it, unless you are building it on a breadboard so you can play with the oscilloscope. Otherwise, if your intention and purpose are to build a power supply, among your concerns should be the efficiency of the design (note: I am not talking only about the electrical efficiency). What you have there is, more or less, another version of a 555 buck: it may have an educational value, or serve some personal amusement, but it's not practical.
