I am writing to the flash memory of an STM32G474RE using the HAL libraries.
Here is the section of code I've been using:
   /* Unlock the Flash to enable the flash control register access *************/
   HAL_FLASH_Unlock();
   /* Clear OPTVERR bit set on virgin samples */
   __HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_OPTVERR);
   EraseInitStruct.TypeErase    = FLASH_TYPEERASE_PAGES;
   EraseInitStruct.Page         = ADDR_FLASH_PAGE_255;
   EraseInitStruct.NbPages      = 1;
   EraseInitStruct.Banks        = 2;
   HAL_FLASHEx_Erase(&EraseInitStruct, &PAGEError);
   HAL_FLASH_Program(FLASH_TYPEPROGRAM_DOUBLEWORD, ADDR_FLASH_PAGE_255, 0);
   HAL_FLASH_Lock();
The first program function works, if I erase all flash on debugging. However the following erase function does not work. I can monitor the values in the flash locations using STM32CubeIDE.
When I change
   EraseInitStruct.TypeErase    = FLASH_TYPEERASE_MASSERASE;
The erase function will start to work. But of course the whole bank gets erased. Which is not what I want.
What I don't understand is if I change
   EraseInitStruct.Page         = ADDR_FLASH_PAGE_128;
Only page 128 gets erased?
Can anyone explain why I can page erase page 128 but not 255? They're the same bank, the program memory is in a different bank, I can erase other pages in this bank? The datasheet also specifies that I can do pages erases?
Any insight is appreciated.
I've found the issue.
is supposed to be the page number of the bank (0-127). ADDR_FLASH_PAGE_XXX is the memory address of the start of the page.
