As far as I know one can calculate a chip’s (Diode, Transistor..) junction temperature rise with the consumed power and the thermal resistance Rth.
Is there a way to calculate the junction temperature without the power but based on the temperature measured on the Chip‘s case and Rth or other datasheet values?
The reason for this question is my desire to check the temperature handling on an existing PCB without changing it by my measurements (for example soldering some parts up for current measurments).
There is a way using no air flow with Rjc thermal resistance to estimate active junction temperature.
You must know Pd, Tamb and Rjc to compute Tj or for THT parts if given Rjc, Rca... for j = junction, c= case and a= ambient....and T= temp. SMT parts depend on substrate greatly.
But comparing mounted and uncounted parts could derive these values for Rca using similar small sized parts like 220’C/W in small transistors. (Not tried)
Tj= (Tc-Tamb)*Rca/Rjc+Tamb.. (? Verify?).
Often Only Rja is given due to many differences in substrate material and area so guidelines are given.
Due to latency of thermal mass in power devices you must also know the Safe Operating Area or compute the junction thermal pulse response if an OEM like Rohm provides the RC time constants for each layer of material.
Another active method is to use a pulsed off current to measure the threshold voltage of a PN junction which has a known thermometer characteristic at 1mA. e.g. ~600 mV @ 25’C @ 1mA for Vbe then apply the NTC slope to estimate Tj.
Calibration in boiling water will serve to verify assumptions of a discrete part.
In general the lead temp may be closer to Tj than the epoxy insulated body. This is especially true for Cathodes on epoxy LED’s where the cup-holder is attached while the anode is bonded with a whisker gold wire that is a poor heat conductor and fuses easily yet is almost invisible.
Yet ultimately, if your case temp is too hot to touch > 65’C at room temp, you may have a Tj reliability problem at 40’C ambient. Arrhenius Law states for every 10’C rise the MTBF reduces 50%. There may be exceptions for some materials that this applies every 12’C rise above ambient.
  • \$\begingroup\$ Could you please elaborate or provide a link on the method you mentioned in the first sentence? \$\endgroup\$
    – Amigo54
    Mar 15, 2021 at 9:42
  • \$\begingroup\$ Why can’t you search for thermal resistance and Rjc Rca for a complete understanding. \$\endgroup\$ Mar 15, 2021 at 11:37
  • \$\begingroup\$ thermal resistance rjc rca... duckduckgo.com/… \$\endgroup\$ Mar 15, 2021 at 11:38
Thermal resistance calculations are essentially resolving the temperature drops of all the interfaces
\$T_{junction} = T_{ambient} + P_{total}\times R_{thJA} \$
In this instance you know the ambient temperature, you know the case temperature BUT you do not know the power dissipated, thus there is an unknown in your equation required to determine the junction temperature
  • \$\begingroup\$ How does the case temperature help me in the shown equation, as it is not part of it? Aren‘t there two unknowns (Ptotal and Tjunction)? \$\endgroup\$
    – Amigo54
    Mar 14, 2021 at 17:59
