Is it possible to control the ESP32-Cam GPIO from the web? Just like a "normal" ESP32 can create a website with buttons that turn on and off certain GPIOs
Was wondering because I can't find anything on the internet it only shows the normal ESP32
Note: I have ESP32M compatible with CAMERA_MODEL_AI_THINKER, and wanted to transmite video feed from the esp to a website and on the same website having buttons that control the GPIO pins for that esp32-cam
Yes, the ESP32CAM can do all the things that the regular ESP32 can do, you just don't have access to as many GPIO. Only GPIO 2,4,12-16 are broken out to pins on the ESP32-CAM.
  • \$\begingroup\$ many thanks! It's all good to me since I only want to control a 4 relay module so I conly need 4 pins. Is the code different or the way you create the webpage is exactly the same? \$\endgroup\$ Commented Mar 15, 2021 at 14:40
  • \$\begingroup\$ @AndréClérigo An ESP32Cam is a regular ESP32 with some camera hardware stuck to it. If you know how to create code to control relays via a website on a regular ESP32, you can do the same with an ESP32Cam. \$\endgroup\$
    – StarCat
    Commented Mar 15, 2021 at 14:55
  • \$\begingroup\$ Awesome, thx for the help! \$\endgroup\$ Commented Mar 15, 2021 at 14:56
