I need to change the final value of the string in several NetLabel in Altium Designer 21. For example, I need to change RED0_U1 to RED0_U4, RED1_U1 to RED1_U4 and so on. I would like to know if there is a simple way where you can change the value of all similar nets at the same time without having to change one for one.
You can easily do that with the "SCH LIST" panel (right bottom of your Altium window).
1 - Select all your labels.
2 - Open SCH List enter image description here 3 - Select the column Text
4 - Right click -> Smart Edit
5 - Set your changement
6 - Enjoy
  • \$\begingroup\$ That worked, thank you! \$\endgroup\$ Mar 15, 2021 at 16:16
