the equation is used to calculate the power of RCD, I know this power is from leakage inductor the inductor energy can use 1/2Li^2 to express, but I don't know how to get this document equation.
Can someone give me some help?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communitythe equation is used to calculate the power of RCD, I know this power is from leakage inductor the inductor energy can use 1/2Li^2 to express, but I don't know how to get this document equation.
Look at the formula: -
It's energy multiplied by frequency and that energy is the energy dissipated by the clamp circuit per switching cycle. In other words Power = energy x frequency.
And, that energy is \$\frac{1}{2} \cdot V_{CLAMP}\cdot I_P\cdot \Delta_t\$
We also know that power x time = energy hence,
Power = \$\frac{1}{2} \cdot V_{CLAMP}\cdot I_P\$
And this is the average power dissipated by the RC clamp in a switching cycle. It's basically half of "V x I" (power) where \$V_{CLAMP}\$ is constant (as said in the linked document) and the current waveform will be a linearly ramping down current starting at a peak of the initial current dcue to the stored energy in the inductor.
When you multiply those two terms you get an average power of \$\frac{1}{2} \cdot V_{CLAMP}\cdot I_P\$.
That formula comes from a balance of Energy at each cycle, in flyback topologies in discontinuous conduction mode.
