I have this circuit. The goal is that it going to control the current loop by using the NPN-transistor. My problem here is that 0V results that the output from the Op-amp is near 24V. Why?
If I'm increasing the voltage a little bit, then I got this.
And even better, If I implement a schottky diode, then I got this.
So why does the output goes to near 24V when the non inverting input is 0V?
  • \$\begingroup\$ There should be a pull-down resistor at the base of the NPN transistor. Most op amps can not output a voltage equal to the bias voltages (24V and GND in this case), so the output can't go to zero. Probably better to reduce 10k to lower value. \$\endgroup\$
    – Ernesto
    Commented Mar 16, 2021 at 17:59
  • \$\begingroup\$ @Ernesto Thank you! I will try that! \$\endgroup\$
    – euraad
    Commented Mar 16, 2021 at 18:05
  • \$\begingroup\$ @Ernesto Did not work. Are you sure about there should be a pull-down resistor (e.g 10K) before the base of the NPN transistor? \$\endgroup\$
    – euraad
    Commented Mar 16, 2021 at 18:09
    \$\begingroup\$ There doesn't need to be a pull down @DanielMårtensson - always check someone's reputation before starting a wild goose chase LOL. Falstad isn't that good. \$\endgroup\$
    Commented Mar 16, 2021 at 18:10
  • \$\begingroup\$ @DanielMårtensson I should have qualified my statement as I think this might fix it. I think now that 0V is not a voltage source but a open connection, maybe try adding 0V voltage source? \$\endgroup\$
    – Ernesto
    Commented Mar 16, 2021 at 18:36
6
It looks OK in my simulator: -
0 volts in produces near enough 0 volts out (well, 7.847 μV) with a drive level from the LM324 of around 200 mV.
If I increase V1 to 100 mV, it all makes sense too: -
I suspect that Falstad (is that your sim?) is having problems (after all, it's pretty much a toy when it comes to sim tools) but, importantly, the LM324 will never have problems with inputs or outputs close to 0 volts because it was designed to encompass the negative supply rail, especially so the inputs.
  • \$\begingroup\$ Great! So Flastad have some issues here. What software are you using? \$\endgroup\$
    – euraad
    Commented Mar 16, 2021 at 18:11
    \$\begingroup\$ Microcap 12 - it is currently free. \$\endgroup\$
  • \$\begingroup\$ Thank you very much! \$\endgroup\$
    – euraad
    Commented Mar 16, 2021 at 18:12
    \$\begingroup\$ @jusaca I've been using microcap since circa 2005 and LTSpice has a few anomalies I don't like (differential time measurement for one and not as well-rounded as microcap). \$\endgroup\$
    Commented Mar 17, 2021 at 10:31
    \$\begingroup\$ @Andyaka never heard about Micro Cap. Only LTSpice. Thanks! \$\endgroup\$
    – euraad
    Commented Mar 17, 2021 at 23:39
10
The LM324 model (or the simulation) is seriously broken.
LM324 input common mode range includes the negative (and a bit more) so this should never happen for non-inverting input within 100mV of 0V. (If you drive the non-inverting input well below 0V, the output can be driven high, but that's not happening here).
Raise the non-inverting input to 500mV and it outputs a negative voltage. That is never going to happen either.
Suggest not wasting time with this software. LTspice is another serious option.
    \$\begingroup\$ +1 for LTSpice since it runs very well with wine, like he mentioned \$\endgroup\$
    – devnull
    Commented Mar 16, 2021 at 18:39
