I'm trying to hook up an OLED display using I2C communication to my Arduino Pro Mini clone(with ATmega 168, 16MHz) from WAVGAT but I can't figure out where the I2C pins are on the Arduino.
\$\begingroup\$ I2C pins on the Arduino or the OLED display? if display, which one are you using? They are not all the same. \$\endgroup\$– jwh20Mar 18, 2021 at 12:07
\$\begingroup\$ on the arduino. \$\endgroup\$– ahmedMar 18, 2021 at 12:08
\$\begingroup\$ So what does the Wavgat manual say about it? \$\endgroup\$– JustmeMar 18, 2021 at 12:08
\$\begingroup\$ I can't find the manual \$\endgroup\$– ahmedMar 18, 2021 at 12:09
1 Answer
The "official" Arduino Pro Mini pinout is:
So your I2C pins SHOULD BE at the A4 and A5 positions. There doesn't seem to be any information on the WAVGAT model. But that's common with Chinese knock-offs. You get what you get and may have to improvise.
