I have interfaced a HID bar-code scanner with LPC2468 using interrupt transfer. The polling interval which i receive(from bar-code) in the Endpoint Descriptor is 10 ms. What will happen if i increase or decrease this polling interval.
  • \$\begingroup\$ Apparently (according to this datasheet) it can scan up to 330 times per second. \$\endgroup\$ – Oli Glaser Jan 18 '13 at 11:07
  • \$\begingroup\$ @PeterJ: Some scanners are good at picking up moving objects. There would be some applications where one might want to catch the barcodes of objects that are zooming by on a conveyor or transport, and some conveyors/transports may have things zooming along at pretty incredible speeds. (though to be sure, I wouldn't normally expect a handheld device to be humanly-held near such a high-speed conveyor running at speed). \$\endgroup\$ – supercat Jan 18 '13 at 17:47
  • \$\begingroup\$ If one has a scanner which is permanently mounted to watch a high-speed conveyor, using a 10ms polling interval rather than 1ms will add a random delay of up to 9ms before an object can be reported. That wouldn't be an issue if one were hand-pointing the scanner at barcodes for purposes of logging them, but could be a problem if the barcodes were being used in "real time" to e.g. route objects on a conveyor. Even if the conveyor only handles one object per 100ms, a diverter may need to be triggered within a 20ms window. An extra 9ms timing uncertainty won't help. \$\endgroup\$ – supercat Jan 18 '13 at 18:03
If you poll if more/less frequently, assuming it is ready to send data, then it will simply be a case of receiving data more or less frequently.
I'm not sure if you have read this programming manual, but if you haven't then you should. It appears (at a glance) that it is configured using the barcodes themselves (as opposed to a message from the PC.
All the configuration barcodes are there, and there is a section on changing the inter-message delay. I would try using these (set delay to 0 between messages), poll at your desired speed (up to 1 / 330 = ~3ms polling interval) and let us know how it goes.
Here is a clip of some relevant settings in the "General Configuration" section (note the "start of configuration" and "end of configuration" barcodes):
Delay Configuration
| improve this answer | |
  • \$\begingroup\$ Can some data get lost due to overwriting or other reason if i increase polling interval \$\endgroup\$ – Sarao Jan 18 '13 at 12:01
  • \$\begingroup\$ Not at the USB level, no - the device should just respond with a NAK to tell the PC to wait if it is not ready to send more data yet. \$\endgroup\$ – Oli Glaser Jan 18 '13 at 13:30
  • \$\begingroup\$ +1, "not sure if you have read this programming manual" \$\endgroup\$ – Anindo Ghosh Jan 19 '13 at 17:44
