I am trying to place components in Altium designer using the Manufacturer part search but the "Place" option is inactive.
Altium Manufacturer Part Search.
  • \$\begingroup\$ This means that the library doesn't have a footprint/schematic linked. \$\endgroup\$
    – Harnex
    Mar 19, 2021 at 7:34
You have to be connected and signed in. Look in your picture top right, You are not connected. Also make sure that your license is valid
Not all components in the manufacturer part search can be placed directly into the design. The green circuit symbol shows if the required model data is available. You can directly place components with this symbol. For other components, you might have to create your own footprint and schematic symbol or use other external libraries. You can still use the parameters that are provided in the manufacturer part search though. Also notice that you can specifically filter for "Has Model".
Manufacturer Part Search Altium
enter image description here Source: Altium Documentation
enter image description hereclick on "ALL" instead of "MOSFETs"
