I'm a mathematics and physics student. I am trying to simulate the circuit from the paper "Design and implementation of a lightweight high-voltage power converter for electro-aerodynamic propulsion". However, this is my first time using LTspice and I'm struggling with it.
What I don't understand is why the signal in the voltage in the primary of the transformer isn't sinusoidal as expected but rather a DC signal of 100V. Consequently the signal isn't being multiplied by the transformer and the output voltage is 0.
Picture of the circuit from LTspice: enter image description here
Node n004 is the node linked to the primary of the transformer:
Edit: The link to the article was not working so I replaced it with another one.
  • \$\begingroup\$ See if this doesn't help. \$\endgroup\$ Mar 21 at 15:17
  • \$\begingroup\$ @aconcernedcitizen I'm not sure I'll try it out. I tried a version of this circuit where the MOSFETs are replaced by open and closed switches and the voltage of the coil becomes 0. \$\endgroup\$
    – Voltini
    Mar 21 at 15:33
  • \$\begingroup\$ If this is copied from the IEEE article I can’t access, your supply and pulses are inverted or you are using the wrong polarity of FETs \$\endgroup\$ Mar 21 at 15:42
  • \$\begingroup\$ The must also be at least x us of deadtime to prevent cross conduction shorts. Read how to design a Boost converter.... \$\endgroup\$ Mar 21 at 15:44
    \$\begingroup\$ @TonyStewartSunnyskyguyEE75 I edited the link you should be able to access the article \$\endgroup\$
    – Voltini
    Mar 21 at 15:50
All your PMOS are upside down hence the parasitic diode in each (show by my red lines) is conducting a massive and unfeasible current from the power source: -
Given that the four PMOS are identical, the outputs will from a 2:1 potential divider and convert your input supply of 200 volts into an output of 100 volts.
I think you need to relook at what the original idea is behind your simulation because 4 MOSFETs wired like this can never properly work.
Original idea (oops they got that wrong):
Unfortunately, you can't rely on the diagram in the document you cite. It also shows PMOS devices (wrong) and also shows each half bridge gates connected together (also wrong): -
Here's a blow-up of Q1: -
Clearly and unambiguously, this is incorrectly drawn as a P channel MOSFET when it should be either an N channel MOSFET or a P channel device with source and drain reversed.
  • \$\begingroup\$ I have tried replacing the MOSFETs in another simulation with closed and open switches (when M1 and M4 are closed M2 and M3 are open), and the voltage output becomes 0. \$\endgroup\$
    – Voltini
    Mar 21 at 15:21
  • \$\begingroup\$ @Voltini then you are probably doing that 2nd circuit wrong also. I've explained where the main problem lies in the circuit you have shown in your question and that should be enough to fix it. Start simple with MOSFETs/switches - use one switch and a resistive load connected to the battery and get that working first. Don't jump in the deeper end first. They can be tricky to get right for newbies. \$\endgroup\$
    Mar 21 at 15:43
  • \$\begingroup\$ Is it possible to fix the circuit? \$\endgroup\$
    – Voltini
    Mar 21 at 16:21
  • \$\begingroup\$ It's possible to fix it in your simulation suite by using NMOS devices and using care in applying the proper gate-source voltage on each device (no connecting upper MOS gate to lower MOS gate because that will never ever work). Then, to get it to work in practice requires a few calculations and application of proper MOSFET driver circuits @Voltini \$\endgroup\$
    Mar 21 at 16:26
  • \$\begingroup\$ All - Please keep things civil and remember the Code of Conduct. Polite technical disagreement is allowed. However, don't post anything that could feel personal, even when applied to content and not the person. \$\endgroup\$
    – SamGibson
    Mar 21 at 18:09
The ambiguity is in the symbols used to show an NCh FET. This one is special made from GaN.
The simplified schematic is in error. (draft-person error)
So your simulation must use the exact same parts and exact same layout to come even close to what the designer ended up with for every part!!
I don’t know the history of FET symbology but when it looks like a BJT with 1 plate for the gate and a horizontal arrow for the source going out to look like an NPN, it is not really a Pch FET as you and another answer writer believe, but rather it is a very special GaN NCh FET.
https://www.mouser.com/datasheet/2/692/GS66504B%20DS%20Rev%20160229-938232.pdf
Authors of these IEEE papers rarely show all their trade secrets with an accurate full design spec, simulation but at least a BOM is given (Bill of Material, partial)
Most of them have bugs they never admit to from parasitic instability or other issues.Yet this author is from MIT so I hope he did achieve some success on kW/kg but there is no mention of MTBF stress margins and heat rise Etc. Yet no DVT results and you never see this in IEEE papers which is standard in electronics industry, which I have done in every company I have worked for. without prior experience on these designs your chances of simulating this are slim without 3mos of dedicated work and research.
Anecdotal
My son-in-law (Prof @ U of T) has designed such inverters for DC stackable microgrids several years ago, so this is not really new technology yet novel enough because of the propulsion application.
  • \$\begingroup\$ It clearly and unambiguously is using a P channel MOSFET symbol in the original document . [Content edited by moderator] \$\endgroup\$
    Mar 21 at 16:28
    \$\begingroup\$ OK the schematic is wrong. It’s a positive Vds max not negative.i.stack.imgur.com/HoF5o.png. rookie error or. Murphy’s Law, if anything can be inverted , it will be. [Content edited by moderator] \$\endgroup\$ Mar 21 at 16:31
  • \$\begingroup\$ Why would simulating this circuit be hard? I'm doing this as a project for my studies and I don't need the simulation to describe the exact same behavior as in real life, a rough approximation would be enough \$\endgroup\$
    – Voltini
    Mar 21 at 16:55
  • \$\begingroup\$ If replacing the PCh FET with a NCh one would solve the problem and allow me to continue my project it wouldn't be that big of a deal \$\endgroup\$
    – Voltini
    Mar 21 at 16:59
  • \$\begingroup\$ This problem is as basic as 4 diodes in a bridge with the wrong orientation. But your project to emulate this design is miles away. To a math expert is like showing how to integrate an exponential to solve Fermat’s theorem. \$\endgroup\$ Mar 21 at 18:08
