I have the following step response of a closed loop system. Using the calculations below, I tried to calculate the transfer function. I am trying to get the same response in Matlab. However, I seem not get it right. Can someone please tell me what I am doing wrong? My result in Matlab as well is given below.
1\$\begingroup\$ Envelope calcs: \$\alpha=\frac12\cdot 1.993=0.9965\$, \$\omega_{_0}=\sqrt{28.41}\approx 5.33\:\frac{\text{rad}}{\text{s}}\$, \$\zeta=\frac{\alpha}{\omega_{_0}}\approx 0.187\$. So, I get a very low damping factor; which would appear to explain your matlab results. The value of \$\omega_{_0}\$ also appears to match, at least by eye. \$\endgroup\$– jonkMar 21, 2021 at 21:40
2\$\begingroup\$ It's because the system is nonlinear, so you can't estimate it with 2nd order linear system. You can see the difference: yours (linear) VS. scope (non-linear). \$\endgroup\$– Marko BuršičMar 21, 2021 at 22:29
1\$\begingroup\$ Further it has a dead time, a closed loop would have also a numerator part with laplace operators. Could be a kind of controller with limiters that introduce the non-linearity. \$\endgroup\$– Marko BuršičMar 21, 2021 at 22:34
1 Answer
You should not do T = feedback(H,1)
, just do step(H)
The output you have is already the result of the whole system (the whole closed-loop system, not the plant that will then have a feedback), so you should just do step(H)
and you will get something similar to the oscilloscope measurement. In order to further break down the identification into what is the behavior of the controller and what is the behavior of the plant you would need more measurements.
Also, as Marko Buršič mentioned, the system is nonlinear and your approximation will not look\behave exactly as the original system. But I would not go as far as he did in saying that "you can't estimate it with 2nd order linear system". In many cases you can get away with approximating nonlinear systems with some 1st, 2nd or Nth order transfer function. But it will be up to you to evaluate if that 2nd order TF will be enough for your problem.
