I am having trouble understanding the definitions for the transistor. I am checking many different transistors and unfortunately every company has different words/symbols. For example, in one company's transistor datasheet Io was the max output current, very easy to understand and Von was the voltage required to turn on/off the transistor.
Checking different transistors and datasheets I came through different terms.
On this datasheet I understand that I can have up to 10A current flow through the transistor (the load which the transistor drive to be up to 10A), up to 60V but max 20W(V*I).
Where is it written though how much voltage/current needs to be applied to base to turn on/off the transistor?
Why every company is using different terms?
EDITED: The other transistor I was referring to, wasn't mosfet but NPN transistor. Datasheet can be found here I am applying 3.3V from a microcontroller and transistor seems to work.. however from what I read here from you I understand that its not the voltage that enables this transistor but the current.. Is that correct?
