For my school project, I am designing a small PCB. For routing the signals I need to use a via. There will be around 500mA current flowing through the via. I am using 0.5mm traces to route the signals. At present, I have selected 0.75mm hole size and 1.35mm diameter for the via. Are these values okay? It might be a silly question but if someone could kindly explain to me what these two values actually represent and what's their significance?
Thank you
Hello, thank you very much for your reply. it was really helpful. I have a two-layer board and I have 35um copper both on the top and bottom layer. Regarding the plating thickness, isn't the bottleneck here the thickness of the copper within the via hole? I performed a check in the website:
http://circuitcalculator.com/wordpress/2006/03/12/pcb-via-calculator/ .
I am attaching a screenshot here:
Here I have assumed the plating thickness to be 10um(very small) and it shows me the via has an estimated Ampacity of 1.74 amps. I might be missing something here and also my assumption of the plating thickness has been done by checking some other articles here in StackExchange. I would b highly glad if someone could kindly clarify if my estimation is correct.
Thank you again.
