One cycle of a sine wave (such as the mains power voltage) consists of two half cycles (often called positive and negative in electronics).
Is there a (preferably one-word) term to refer to such a sine wave half cycle?
I have seen the term half sine wave, but it is hardly better. And besides, I believe this refers to all positive or all negative half cycles in aggregate, not to individual half cycles.
I am especially interested in this in regards to the mains power.
  • 6
    \$\begingroup\$ I'd call it a positive half cycle. \$\endgroup\$
    Commented Mar 23, 2021 at 17:17
  • \$\begingroup\$ "Swing" sounds appropriate. Pity no one is using it :) \$\endgroup\$
    – Eugene Sh.
    Commented Mar 23, 2021 at 17:21
  • \$\begingroup\$ I think "positive half cycle" is good. Brainstorming alternatives: maybe "first pi"? \$\endgroup\$
    – KD9PDP
    Commented Mar 23, 2021 at 18:04
  • \$\begingroup\$ expanding on @EugeneSh. comment ... upswing \$\endgroup\$
    – jsotola
    Commented Mar 23, 2021 at 18:37
As is often the case, it depends on context. If the entire waveform is present, but you you want to point out a particular half-cycle, you should say "positive half cycle" or negative half-cycle. If you have a zero-crossing switch that lets through a half cycle out of every 5 cycles then you have a series of "sinusoidal pulses" or a series of positive or negative "sinusoidal pulses." You might shorten that to "sine pulse."
  • \$\begingroup\$ +1 for sine pulse \$\endgroup\$
    – Neil_UK
    Commented Mar 23, 2021 at 19:36
I'm not a aware of a specific term, but if you introduce it you can use you can invent your own terminology, eg "hump" "sinus" "pulse".
I really like the sound of a sine pulse that @CharlesCowie suggested. Unfortunately, it seems a little ambiguous to me whether it refers to a half sine cycle or a full sine cycle.
I propose a sine lobe. It does not sound as good as the sine pulse but I believe is less ambiguous.
