I have a module which takes two parameters, ParameterOne
and ParameterTwo
. I use their ratio a lot, so I gave it a name const integer Ratio = ParameterOne/ParameterTwo
I want to have a signal whose width is this ratio, so I defined a signal logic [Ratio-1:0] wires
. However, I get the error message Range must be bounded by constant expressions.
This leaves me perplexed, as this range is bounded by a constant expression (I explicitly declare it to be const
Does anyone here know why it's complaining about this code?
