I am trying to repair the flash of a P900 camera, since it gives a burning smell after being used.
After disassembling the flash unit, I came across this part for which I need some professional eyes in order to identify what kind of component that is.
    \$\begingroup\$ Looks like a teeny-tiny auto-transformer for generating the high voltage for the flash. Is that the hot shoe it's attached to? \$\endgroup\$
    – brhans
    Mar 24, 2021 at 14:27
    \$\begingroup\$ Looks to me like the trigger coil. Is there a 3rd wire going to it on the underside perhaps ? \$\endgroup\$ Mar 24, 2021 at 14:28
  • \$\begingroup\$ Nikon Coolpix P900 is a nice camera (irrelevant of course). \$\endgroup\$
    Mar 24, 2021 at 14:33
  • \$\begingroup\$ thanks for the quick replies. i added another image to the question. \$\endgroup\$ Mar 24, 2021 at 14:39
    \$\begingroup\$ Nikon Coolpix P900 Camera Pop-Up Flash w/ View Finder Assembly Replacement Part ebay.com/itm/… \$\endgroup\$
    – tlfong01
It is the trigger transformer that provides high voltage to the trigger plate in the bulb. This ionises the gas inside the tube, making it conductive and thereby initiating the flash.
A more in depth explanation of the operating principle of such a flash circuit can be found here.
  • \$\begingroup\$ i see, thanks for the fast answer. is dc or ac supplied to the bulb itself? \$\endgroup\$ Mar 24, 2021 at 14:52
    \$\begingroup\$ @abdussamed17 DC. A charging circuit charges up a capacitor with a high DC voltage which is applied across the bulb, ready to go. A pulse on the trigger plate ionises the gas in the tube allowing the DC voltage to arc trough. \$\endgroup\$ Mar 24, 2021 at 14:57
