I have an issue with the following schematic:
When I am doing a hot swapping on the RS422 (Local console) connector X1200, my fuse F1200 blow up. I have a TVS diode to protect against overvoltage on power line (+36VDC) against ESD. However I don't have TVS diodes on Tx, Rx, gnd lines. Can it be the issue ? How could I prevent my fuse F1200 to blow up if the user is doing a hot swapping ?
I already check the fuse sizing and the typical current used is about 1 A, so it can't be a fuse sizing issue.
Additional information: VSL is +36 VDC and its power coming from an external power supply. This power is sent directly to pin 6 of connector X1200 in order to power supply an external circuit which is a console (containing a display unit, touchscreen, ssd.... (small computer)). This power supply is received by the external circuit then buffered. In the following picture you will see reception of the power supply by the external circuit.
Thanks for your help, Regards,
