I am a Computer Engineering student currently learning computer architecture, and working on modeling a booth's algorithm in VHDL. My design hierarchy contains a datapath and a control unit. The datapath contains primary sub-components (ALU, decrement counter, M register, product register). The control unit is just programmed as FSM. The said components are connected in a datapath module using port mapping. The module is shown below:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity datapath is
    Port (
        -- INPUTS
        clk : in STD_LOGIC;
        load_m : in STD_LOGIC; -- LOAD pin for M (tells unit to load M or not)
        m_in : in STD_LOGIC_VECTOR (7 downto 0); -- loaded multiplicand M
        q_in : in STD_LOGIC_VECTOR (7 downto 0); -- multiplier
        -- REST CONTROL INPUTS
        k : in STD_LOGIC; -- ALU pin (determines if add or sub operation)
        alu_enable : in STD_LOGIC; -- enables ALU function
        c_load : in STD_LOGIC; -- LOAD coming from controller (tells prodreg if it should load the value from ALU to Accumulator)
        dc : in STD_LOGIC; -- decrement pin (tells counter to decrement counter value)
        shift : in STD_LOGIC; -- SHIFT pin (tells prodreg to do arithmetic shift operation)
        --OUTPUTS
        count_out : out STD_LOGIC_VECTOR (3 downto 0); -- output counter value
        q01 : out STD_LOGIC_VECTOR (1 downto 0); -- output q01 per clock cycle
        a_out : out STD_LOGIC_VECTOR (7 downto 0); -- output a per clock cycle
        q_out : out STD_LOGIC_VECTOR (7 downto 0); -- output q per clock cycle
        m_out : out STD_LOGIC_VECTOR (7 downto 0) -- output m per clock cycle
end datapath;
architecture Structural of datapath is
component mreg
    Port (
           clk : in STD_LOGIC;
           m_out : out STD_LOGIC_VECTOR (7 downto 0));
end component;
component alu
    Port (
        a : in STD_LOGIC_VECTOR (7 downto 0);
        m : in STD_LOGIC_VECTOR (7 downto 0);
        k : in STD_LOGIC;
        a_out : out STD_LOGIC_VECTOR (7 downto 0));
end component;
component prodreg
    Port (
           clk : in STD_LOGIC;
           a_in : in STD_LOGIC_VECTOR (7 downto 0);
           q01 : out STD_LOGIC_VECTOR (1 downto 0));
end component;
component counter
    Port (
           clk : in STD_LOGIC;
           dc : in STD_LOGIC;
           count_out : out STD_LOGIC_VECTOR (3 downto 0));
end component;
-- intialized alu and prodreg signal ports as '0's
signal dp_m : STD_LOGIC_VECTOR(7 downto 0);
signal alu_a_in : STD_LOGIC_VECTOR(7 downto 0) := (others => '0');
signal alu_a_out : STD_LOGIC_VECTOR(7 downto 0) := (others => '0');
signal pro_a_out : STD_LOGIC_VECTOR(7 downto 0) := (others => '0');
begin
    port_mreg: mreg port map(clk, m_in, load_m, dp_m);
    port_alu: alu port map (alu_a_in, dp_m, k, alu_enable, alu_a_out);
    port_prodreg: prodreg port map (clk, c_load, shift, alu_a_out, q_in, q_out, pro_a_out, q01);
    port_counter: counter port map (clk, dc, count_out);
    process(clk)
    begin
        if rising_edge(clk) then
            alu_a_in <= pro_a_out;
            a_out <= pro_a_out; -- accumulator output
            m_out <= dp_m; -- m output (multiplicand)
        end if;
    end process;
end Structural;
For clarity, focus on the alu and prodreg ports. ALU operates as a adder/subtractor but ignoring the final carry bit, prodreg operates as '16-bit arithmetic shift right' for signals 'a' and 'q' (8-bit signals), respectively.
As observed, 'alu_a_in' is intialized as "0", and is set as input of ALU. The output is a sum/diff that is then wired to prodreg as input. This should provide a shifted output 'pro_a_out'. For every clock cycle, I wanted to see the shifted outputs of pro_a_out (shifted a) and q_out (shifted q). After that, the pro_a_out value is used as input to the alu (feedback) for the next operation.
My problem is, as observed in the simulation below, a_out (pro_a_out) is undefined. q_out is also throwing values undefined alternately, but I assume its correctly shifting (this is because q_01 is providing reasonable results, q(0),q(1) respectively). Also, I've test benched every sub-component and they are all providing expected results.
My question is, is the modeled datapath scripted correctly to provide outputs 'a_out' and q_out'? Is the way of providing prodreg feedback to ALU modeled correctly? What changes are needed to be done? I can't find the cause of the problem and I am still quite a novice in VHDL scripting. Testbench is also provided below.
TESTBENCH
library IEEE;
use IEEE.Std_logic_1164.all;
use IEEE.Numeric_Std.all;
entity datapath_tb is
end;
architecture bench of datapath_tb is
  component datapath
      Port (
          clk : in STD_LOGIC;
          k : in STD_LOGIC;
          dc : in STD_LOGIC;
  end component;
  signal clk: STD_LOGIC;
  signal load_m: STD_LOGIC;
  signal m_in: STD_LOGIC_VECTOR (7 downto 0);
  signal q_in: STD_LOGIC_VECTOR (7 downto 0);
  signal k: STD_LOGIC;
  signal alu_enable: STD_LOGIC;
  signal c_load: STD_LOGIC;
  signal dc: STD_LOGIC;
  signal shift: STD_LOGIC;
  signal count_out: STD_LOGIC_VECTOR (3 downto 0);
  signal a_out: STD_LOGIC_VECTOR (7 downto 0);
  signal q_out: STD_LOGIC_VECTOR (7 downto 0);
  signal q01: STD_LOGIC_VECTOR (1 downto 0);
  signal m_out: STD_LOGIC_VECTOR (7 downto 0) ;
  constant clock_period: time := 10 ns;
  signal stop_the_clock: boolean;
begin
  uut: datapath port map ( clk        => clk,
                           load_m     => load_m,
                           m_in          => m_in,
                           q_in          => q_in,
                           k          => k,
                           alu_enable => alu_enable,
                           c_load     => c_load,
                           dc         => dc,
                           shift      => shift,
                           count_out  => count_out,
                           a_out      => a_out,
                           q_out      => q_out,
                           q01        => q01,
                           m_out      => m_out );
  stimulus: process
  begin
    --product should be 30 (00011110)
    load_m <= '1';
    m_in <= "00001111";
    q_in <= "00000010";
    k <= '0';
    alu_enable <= '0';
    c_load <= '0';
    dc <= '0';
    shift <= '0';
    wait for 15 ns;
    load_m <= '0';
    k <= '0';
    alu_enable <= '1';
    c_load <= '0';
    dc <= '0';
    shift <= '0';
    wait for 10 ns;
    k <= '0';
    alu_enable <= '0';
    c_load <= '1';
    dc <= '0';
    shift <= '0';
    wait for 10 ns;
    k <= '0';
    alu_enable <= '0';
    c_load <= '0';
    dc <= '1';
    shift <= '1';
    wait for 10 ns;
    k <= '1';
    alu_enable <= '1';
    c_load <= '0';
    dc <= '0';
    shift <= '0';
    wait for 10 ns;
    k <= '0';
    alu_enable <= '0';
    c_load <= '1';
    dc <= '0';
    shift <= '0';
    wait for 10 ns;
    k <= '0';
    alu_enable <= '0';
    c_load <= '0';
    dc <= '1';
    shift <= '1';
    wait for 10 ns;
    k <= '0';
    alu_enable <= '1';
    c_load <= '0';
    dc <= '0';
    shift <= '0';
    wait for 10 ns;
    k <= '0';
    alu_enable <= '0';
    c_load <= '1';
    dc <= '0';
    shift <= '0';
    wait for 10 ns;
    k <= '0';
    alu_enable <= '0';
    c_load <= '0';
    dc <= '1';
    shift <= '1';
    wait for 10 ns;
    --stop_the_clock <= true;
    wait;
  end process;
  clocking: process
  begin
    while not stop_the_clock loop
      clk <= '0', '1' after clock_period / 2;
      wait for clock_period;
    end loop;
    wait;
  end process;
end;
EDIT 5
begin
    --port_prodreg: prodreg port map (clk, c_load, shift, alu_a_out, q_in, q_out, pro_a_out, q01);
    --port_counter: counter port map (clk, dc, count_out);
    process(clk)
    begin
            a_out <= alu_a_out; -- accumulator output
            --alu_a_in <= pro_a_out;
        end if;
    end process;
end Structural;
I tested out individual components output on the datapath port for ALU and prodreg (something I should have done a long time ago). The first simulation shows the usage of only mreg and ALU components. As observed, the ALU provides the appropriate signals of the sums and differences from the component.
Simulation of alu_output on datapath.tb, implying no problems on ALU output
The second simulation uses the same code in the previous one where all components are included (uncomment prodreg, counter). As observed, it also provides the appropriate signals coming from the prodreg as well (shift happens on q_out).
Simulation of ALL components on datapath.tb, implying no problems on port components output
The following simulation just uncomments `alu_a_in <= pro_a_out; while a_out is still derived from ALU, but this time, similar results from the original post are shown. Correct me if i'm wrong, but would this narrow down the problem on the way the feedback signal is introduced between the port map components? If so, what other ways should this problem be approached?
Just to reiterate the concerns:
  1. Problem on introduced feedback signal from prodreg to ALU
  2. When introducing the 1, how come a_out (undefined) and q_out (undefined on alternating clock cycles) are what it is?
The block diagram below represents the overall system being implemented, hopefully this adds as useful for addressing the concern and for why such design is being implemented
Block diagram of the concerned design implementation
To avoid unknowns in the simulation you must ensure that all registers in both the test bench and the unit under test have initial values. Also, make sure that all input ports either have default values or are connected to signals that have a default value, or will effectively have a default value derived from a combination of other signals having a default value.
Specifically, your signal a_out is based on combinations of signals a, k, and m, and is latched by alu_enable. For a_out to have a defined value all of the signals it depends on must also have a defined value.
Also the use of alu_enable to control updating of a_out makes a_out a register (or at least that seems to have been the intent if it were not broken). If you want a_out to have a defined value prior to the first time alu_enable goes high, then you need to specify the initial value in the port declaration.
For example...
entity alu is
    Port (
           k : in STD_LOGIC;
           a_out : out STD_LOGIC_VECTOR (7 downto 0) := (others => '0')
end alu;
Note also that alu_a_out (which is initially undefined) is fed into component prodreg, which would also cause some of its outputs to become undefined (since they depend on alu_a_out).
Also...
These lines of code...
process(alu_enable, a, m)
begin
    if alu_enable='1' then
        a_out <= s;
    end if;
    a_out <= s;
end process;
Are equivalent to...
begin
    a_out <= s;
end process;
So your alu_enable is not getting used.
  • \$\begingroup\$ Hello. I've considered the solution though the outputs on the dataport is still the same as before. Considering the initial values, I also initialized every port declaration in the data path though it still gave same results. However, I acknowledge the change on the ALU process statement and updated it. It has also somehow cleared my confusions on its function. \$\endgroup\$
    – Guorishix
    Mar 24, 2021 at 19:35
    \$\begingroup\$ @Guorishix Initialising the signal in the RTL is never a good thing. This depends on technology and it can cause issues on hardware \$\endgroup\$
    – maximus
    Apr 3, 2021 at 20:03
    \$\begingroup\$ @Guorishix I wouldn't say "never". If you are designing something with the goal of running on all technologies, then sure. There are times were having a reset input is appropriate. There is a tradeoff with the performance (clock rate reduction) and logic utilization (increase) that occur when you add a separate reset. If you are designing with an FPGA that supports it then its fine to use initial values. I have been initializing signals in RTL regularly on Xilinx FPGAs for over a decade without a single issue. \$\endgroup\$
    – user4574
    Apr 5, 2021 at 13:48
At first glance, in your ALU:
begin
        a_out <= s;
    end if;
    a_out <= s;
end process;
Not sure what you are trying to achieve here. The signala_out will always be s regardless of the value of alu_enable.
The sensitivity list of the process() is wrong as well. It should include s and no need of a and m. The process is not triggered by changes in value of s, hence a_out may go undefined, and it in turns trickles down to make pro_a_out undefined as well.
UPDATE:
I see your counter, mreg modules, are synchronous but doesn't have reset signal. Maybe you are initializing during declaration, but it's not a good practice in RTL. So make sure all registers and output ports initialize to a reset value using a reset signal. This applies to your synchronous process in datapath entity as well. It also doesn't have reset.
  • \$\begingroup\$ Hello. I've considered the solution though the output is still the same as before. \$\endgroup\$
    – Guorishix
    Mar 24, 2021 at 19:26
  • \$\begingroup\$ Did you check the alu_out output of ALU component. Not the top entity. You can update the question, if you made changes in specific parts of the code. \$\endgroup\$
    – Mitu Raj
    Mar 24, 2021 at 19:31
  • \$\begingroup\$ Yes. I simulated the ALU_tb, and it seems to work fine. \$\endgroup\$
    – Guorishix
    Mar 24, 2021 at 19:44
  • \$\begingroup\$ Am not talking about individual testbench. You should probe/debug the signal a_out from the component ALU, using the same datapath testbench simulation. Currently you are debugging only the top-level signals. \$\endgroup\$
    – Mitu Raj
    Mar 24, 2021 at 19:46
  • \$\begingroup\$ Your sensitivity list is still wrong as well in the updated code. It should be process (s). However the whole process doesn't make any sense to me on what's its actual functionality. You are just wiring two signals with no logic in between. \$\endgroup\$
    – Mitu Raj
    Mar 24, 2021 at 19:49
