So I am trying to add an SD card to my circuit and unfortunately, all I have left are 4 GPIOs, but I was asked to try and find a solution to only use 2. So using 4 is a worst case scenario. I thought about bit-banging SPI so that is one solution but ideally, I want to use 2 pins only so my guess is SPI is not possible and all is left is I2C bit-banging. I considered using an I2C-SPI bridge (speed is not a problem here), but memory is written in blocks of 512 bytes whereas the bridge sends 200 bytes at a time max.
Any solutions? If a 2-pin solution is not possible, what is the best solution using 4 pins?
  • \$\begingroup\$ How much space do you have available? \$\endgroup\$ Commented Mar 26, 2021 at 10:34
  • \$\begingroup\$ @BruceAbbott what do you mean by space? \$\endgroup\$
    – Nadir
  • \$\begingroup\$ I mean, what physical space do you have (on the PCB etc.) to add components. \$\endgroup\$ Commented Mar 26, 2021 at 10:43
  • \$\begingroup\$ @BruceAbbott I am not sure to be honest but that is not an issue here although the smaller the better of course \$\endgroup\$
    – Nadir
    Commented Mar 26, 2021 at 11:15
  • \$\begingroup\$ You can use that SCI18IS602B I2C-SPI bridge to send & receive 512-byte blocks. The trick would be to configure the SS pin to the SD card as a GPIO and control it 'manually' instead of letting the bridge IC control it automatically. \$\endgroup\$
    – brhans
    Commented Mar 26, 2021 at 15:18
Driving an SD CARD with 2 pins is not possible.
Driving an SD CARD with 3 pins might be doable in 1-bit mode:
Pin 1  ->  CMD
Pin 2  ->  CLK
Pin 3  ->  DAT_0
Take a look here for more detailed info in 1-bit mode:
https://www.keil.com/pack/doc/CMSIS/Driver/html/group__mci__interface__gr.html
As far as I know 2-bit mode doesn't exist.
