I am trying to interface a 16x4 LCD with an atmega32 chip. I wrote the following code which used to work for 16x2 LCD
#include<avr/io.h>
#include<util/delay.h>
#define dataport PORTC // LCD data port
#define commport PORTD
#define en PD6 // enable signal
#define wr PD5 // read/write signal
#define rs PD4 // register select signal
int wrcomm(unsigned int data)
  dataport=data;
  _delay_ms(10);
  commport &= ~(1 << rs);
  commport &= ~(1 << wr);
  commport |= (1 << en);
  commport &= ~(1 << en);
  _delay_ms(10);
  return 1;
int wrdata(unsigned int data)
  dataport=data;
  _delay_ms(10);
  commport |= (1 << rs);
  _delay_ms(10);
  return 1;
int lcd_putchar(unsigned char x)
  wrdata(x);
  return 1;
void lcd_init(void)
  DDRC=0xff;
  DDRD=0x70;
  wrcomm(0x38);
  wrcomm(0x01); //turn on display and cursor
  wrcomm(0x0E);//cursor line 1 postn 1
  wrcomm(0x80);
int main(void)
    lcd_init();
    lcd_putchar('a');
    return 0;
I am guessing that it should work for 16x4 LCD too. But it doesn't. The LCD is a JHD539 164b.
The one thing I have made progress with is that if I do not send any command the 2nd and 4th line remain all black but if I send any command they are all off. The pot is not helping at all.
  • \$\begingroup\$ I can't find a datasheet for your specific display -- do you have a link? Sometimes a display manufacturer uses an "odd" mapping from memory locations to screen locations. You might try writing a different data value to each location in the controller's memory to see if anything shows up on the screen, and figure out the mapping from that. \$\endgroup\$
    – Dave Tweed
    Commented Jan 21, 2013 at 14:04
  • \$\begingroup\$ Why do you bother with the return values? For stuff like this it's mainly waste as there's not way you can detect an error. \$\endgroup\$ Commented Jan 22, 2013 at 18:41
The JHD539-164b is a standard KS0066 compatible character LCD. Nearly Identical to the HD44780 controlled lcds, and user end code would be completely compatible.
The difference between a 16x2 LCD and a 16x4 LCD is only that a 16x4 is really a logical 32x2 LCD, address wise.
If you are not getting it to work, double check the wiring, and see if the lcd is not damaged.
It looks like you are using your LCD display in the 8-bit mode. Make sure in your lcd_init function that you have selected this mode, since LCD controllers have usually 4-bit mode set as a default.
