10
Product Link
Datasheet
I have about fifteen 9v wall warts within specs for the circuit; I'm going to use the one that fits the jack. There are three solder tabs on the jack. One for the positive tip, one for the negative ring/sleeve, and one for the chassis ground. My schematic has Vin and ground specified. I'm relying on the wall wart to appropriately ground the AC end of things. My pos/neg tabs are used for source voltage and ground, respectively, and that leave the third chassis ground tab.
Do I ignore it? Connect it to the negative side ground? To the chassis? What should I do when there's no specification about what to do with the extra tab?
13
I don't think you are correct about a "chassis ground".
Every barrel-connector jack like the image you provide has three pins - Tip, sleeve, and connector-present.
Basically, there is an internal switch that is opened by the presence of a plug in the connector. It's often used to disconnect internal batteries when the device is powered off of an external supply.
Short of a few rather unusual laptop power supplies, every barrel connector I have ever dealt with has been two-conductor only.
    \$\begingroup\$ +1 I hadn't realized the third pin was a connector-present indicator, that makes a lot of sense. \$\endgroup\$
    – vicatcu
    Jan 21, 2013 at 18:35
8
Fake Name's answer is correct, but I want to add an image from the datasheet:
There is no "chassis ground" anywhere in that datasheet.
    \$\begingroup\$ Glad to clear that up...I'd been misinformed. SO if I understand, this symbol indicates a switch between, say battery and wall power? I assume that woul dbe similar to an audio jack that silences the speakers when you plug in headphones? I'm having a major a-ha moment here. :) \$\endgroup\$
    – dwwilson66
    Jan 21, 2013 at 19:02
    \$\begingroup\$ @dwwilson66 yes, exactly. The schematic corresponds somewhat to the physical layout. That "U" on the top left contacts the barrel, and when you shove the plug in (from the left), this lifts up and no longer contacts B. \$\endgroup\$
    – Phil Frost
    Jan 21, 2013 at 19:12
Take a continuity meter to the two 'normally connected' pins out of circuit and I'm pretty sure notice that they ring out... I would say connect them together in your circuit - I have certainly done this in a couple designs (with a center positive jacks).
  • \$\begingroup\$ There is no chassis ground tab in the datasheet. Calling it that will only lead to confusion. \$\endgroup\$
    – Phil Frost
    Jan 21, 2013 at 18:34
  • \$\begingroup\$ @PhilFrost agreed, I have modified my answer accordingly \$\endgroup\$
    – vicatcu
    Jan 21, 2013 at 20:36
