In my kitchen there is a fan to extract air in case it smells during cooking to not make the whole appartment stink like food. When I turn it on, it looks like it is working. But after a bit of time, the sounds it makes change - which seems unexpected.
So I took the blower unit out of its housing. This is what it looks like on its own:
The schematics look like the following (this is what I was able to figure out without opening the fan itself):
I connected it to the mains and let it run for a bit. And sadly it behaved a exactly like in its housing in the kitchen. When the unit starts up being cold, you can feel a strong air flow out of it. After a while the air flow drops to a gentle breeze. This is where I disconnected it from the mains again. I did 2 measurements: First I measured the voltage accross the capacitor: It starts at 280 V AC and slowly drops down. Around 180 V AC there was not much air flow left. What bothered me was that the capacitor heated up. I'm bad at guessing temperatures but it was well above comfortable temperature.
Since I don't have a power analyzer socket, I let it cool down and measured the current it draws. The unit starts at around 200mA. The current exponentially rises. At 350mA you could hear that the motor was spinning slower and at 400mA I disconnected power again.
The label on the fan says 36W which would translate into roughly 160mA. The label on the capacitor says 1,5 uA +/- 10% @ 320V AC.
My multi-meter did not want to measure the capacitor in situ. And since the connectors are crimped and I don't have replacements at hand, I did not want to destroy them, yet.
As the current draw is well above what the unit should have drawn and also the capacitor is getting too hot for my councious, the unit is not getting back into the kitchen anytime soon.
Question: Is this fan salvagable? And if so which component should I replace?
Date of manufacture: 10/1982
Location is Germany, so the mains voltage is 230 V
Edit:
- I measured the capacitor on its own. Also made a technician at a local electronics store measure it. Both measurements came up fine. But that does not mean anything. The fan started blowing fine at first.
- I bought a new capacitor and wired everything up. After 5 minutes the capacitor stayed cool and there was no audible changes in fan speed. Also the voltage across the capacitor stayed between 275V and 280V AC.
Will put everything together tonight and reinstall it. Thanks for the help.
