I have a PIC16F877A and I am supposed to connect 3 LED lights that are series on each output pin the PIC has 40 pins and 33 output pins, if I connect 5 output pins the code I made that will make the lights blink in a certain way works but if I add another output making it more than 5 pins it just keeps on blinking the code I made for the light pattern will not work what is the problem?
