I am programming a LFSR (Linear Feedback Shift Register) in software for learning purposes, and have encountered some limitations in its use as a pseudo-random number generator (PRNG).
- If the seed have few '1' bits and few taps are used, it requires a large "startup time" to produce apparently random output, with almost equal distribution between '1's and '0's or short '0's runs. I guess with more taps such startup would be far quicker, but all precalculated tables I find give two or four taps.
- Sequential numbers are highly correlated, which is to be expected, given that if the output bit is 0 the next number will be half of the previous one. For a 15-bit LFSR with taps [15, 14], plotting a pair of sequential numbers as points in a plane gives the following. An ideal PRNG should spread these points all over the place.
I know that LFSRs are used as fast hardware counter, but I've also seen it is used as a PRNG to create white noise. How is it used in such real world applications with such poor quality?
