I have several lines and arcs in an EAGLE footprint library I need to modify to make thicker. In Altium it's straightforward to hold Ctrl, click on a bunch of objects, open up their properties and change them all at once. In EAGLE I have no idea.
EAGLE's "group" paradigm seems a little far-flung from the standard, so my attempts to use that may be a dead end, but is there some better way? Is there some magic command I could run to give every single line and arc in a library part on layer X a thickness of Y? How about in a PCB, smashing all the parts and changing all their labels to font Z with size W?
