I have just started using Altium as a student after using Eagle for a lot of years.
I download part libraries from sites like Ultra Librarian and can use the supplied script to generate a library with symbol, footprint and 3D body, I can then compile so I can use it in a design.
But this is going to end up with me having hundreds and libraries with just one part in each. How can I create one library and import the downloaded files from Ultra Libary (and others) into that library? Bearing in mind that I have no scripting experience.
Basically, I want to end up with one library for say one brand of MCUs, comm transceivers, connectors etc much like in eagle.
  • \$\begingroup\$ discord.me/altium - then press join server. You may need to create an account. \$\endgroup\$
    Mar 31, 2021 at 10:53
  • \$\begingroup\$ Thanks, very useful, but do you know the answer to my question? I have downloaded and installed that library and it doesn't include most of the components I require. It'll be quicker for me to create download the files from a website and add them to an existing library than waiting for someone to add a part for me. \$\endgroup\$
    – B.Baker
    Mar 31, 2021 at 13:00
    \$\begingroup\$ I did mean for you to get involved in that forum because it is quite active but, the libraries are a bonus @b - it's probably the best place to get advice. \$\endgroup\$
    Mar 31, 2021 at 13:02
  • Open the various individual libraries in Altium.
  • Open the your new target library.
  • Right-click on the component, in the component panel list, that you want to include in your new library, and select 'Copy'.
  • Right-click in your new library and select 'Paste' in the component list.
This works for both Schematic and PCB libraries.
Going from Eagle to fAultium is a big jump. Read the docs. Join the Official Altium forum ( https://forum.live.altium.com ).
