I want to estimate the power dissipation of this IGBT SGL160N60UFD but I can't find any Rdson, I leave the datasheet:
can this TO-264 package handle currents of 100A?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI want to estimate the power dissipation of this IGBT SGL160N60UFD but I can't find any Rdson, I leave the datasheet:
There is no Rds(on) on an IGBT because it does not behave like a MOSFET- it has a Vce(sat).
According to the SOA curve, 100A continuous is not safe even at Tc = 25°C. The limitation is thermal. Note that the Vce(sat) is not guaranteed above 80A so there is uncertainty in the maximum power dissipation at 100A.
300A is the upper limit for a single short pulse starting off at 25°C.
Well, it's an IGBT and it doesn't have a drain (d) or source (s) pin. They are actually called collector and emitter like an ordinary BJT. It does have a gate pin (like a MOSFET) of course.
From the mouser data sheet there is this graph: -
So, clearly it can handle 100 amps (if kept cool) but, the power dissipation will be about 250 watts with a gate-emitter voltage of 10 volts. However, it's a simple jump to convert 2.5 volts and 100 amps to an equivalent on-resistance of 2.5/100 = 25 milli ohms. But don’t run it at this level of current without substantial heat sinking and, not continuously.
This part is marked obsolete on D-K site but not Mouser(?), so no complete datasheet in your link.
But consider for all saturated switches;
$$\dfrac{V_{ce(sat)}}{I_{c(sat)}}=R_{ce}$$
1.3V/80A typ = 16.25 mOhm. 1.6V max. =20 mOhm Max.
1.6V/160A typ = 10 mOhm typ. Not max.
Lookup plot for SOA with PW50 duration @ 100A and consider margin for this “typical” plot.
https://www.mouser.com/datasheet/2/149/fairchild%20semiconductor_sgl160n60ufd-320888.pdf
Always search major distributors instead of others... for datasheets.
Then add 15nH 5mm from device with C values.
The way you model a minority carrier device (BJT, Diode, SCR, IGBT) is via the output characteristic transfer function.
\$V_{ce} = V_{ce0}+ R_0\cdot I_c\$
\$V_{ce0}\$ = on-state voltage threshold \$R_0\$ = On-state resistance approximation
These figures are not provided in the datasheet but can be derived from the Ic vs Vce curve, around an operating point. Once you have derived these figures, the loss can be calculated fairly accurately
In this example I am working around 80A and thus the tangential straight line clips 80A and intersects the x-axis at the approximate \$V_{ce0}\$ ~ 1.4V The ΔI and ΔVce around this point is then used to approximate \$R_0\$ ΔI ~ 80A, ΔV ~0.7V => \$R_0 \approx\$ 8.7mR
Thus the approximate transfer function, around 80A is \$V_{ce} = 1.4V + 8.7m\Omega\cdot I_c\$
Now whether this device should be conducting 80-100A? that is 160-170W, which is only viable IF the die is kept at 25C, which it won't be
