In eagle there is a line that says these have to be connected but the data sheet doesn't mention it. enter image description here
Here is the data sheet in case it helps https://www.mouser.com/datasheet/2/468/RPX_1_0-1903909.pdf
    \$\begingroup\$ The data sheet shows a suggested layout. Maybe you should follow that. \$\endgroup\$ Mar 31, 2021 at 23:17
12 is electrically connected to 6 7 8 internally. If you look at the recommended pcb layout on page 10, it has a pad but its not even connected to anything. Neither are 6 7 8. Its just for heat sinking.
Eagle is showing them as connected because they are the same net. It can be ignored, once you take into account the information from the datasheet.
  • \$\begingroup\$ So, 6 7 and 8 wouldn't be connected to anything? Other than the pad printed on the pcb? That makes sense thank you for clarifying. Would you mind clarifying something else for me? I believe the resistor values under "typical application" don't match with "suggested layout". For example in "typical application" R1 goes from Vin/pin16 to CTRL/pin2, but In "suggested application" R3 goes from Vin/P16 to CTRL/pin2. So the resistor numbers are a bit mixed up right? \$\endgroup\$
    – DRC
    Mar 31, 2021 at 23:58
  • \$\begingroup\$ The numbering of the resistors in a layout isn't important. Its annoying they don't match but the important part is the electrical connections. @drc \$\endgroup\$
    – Passerby
    Apr 1, 2021 at 3:03
