The circuit below supplies 3.3V to an antenna (3.3VGreen), which then gives GNSS info to a control module (ANT_GNSS). The attached antenna is datasheet and only consumes about 10mA Circuit
I'd like to be able to switch the antenna on and off to preserve power, as this application uses a battery. So I thought the circuit below would accomplish this.
BJT circuit
But I am wondering what resistor value I need at the BJT's base to bring the transistor to saturation? The transistor's datasheet is linked here datasheet. I am thinking that if h_fe is 100 @10mA (collector current) then base current needs to be at least 10mA/100 or 0.1mA to drive to saturation? Following this BJT Tutorial, but I have no practical experience.
Somewhere around 0.5 to 1mA is fine, forced beta of 10-20. The transistor is specified at a Ic/Ib = 10, but 20 will be fine too, especially at only 1mA Ic.
So the resistor would be about (3.3V - 0.7V)/0.75mA or about 3.3K\$\Omega\$.
The hFE is specified at Vce = 1.0V and you would like it to be more like 0.1V to minimize the losses in the transistor.
You could also use an inexpensive logic-level p-channel MOSFET such as AO3401A which will have negligible voltage drop.
  • \$\begingroup\$ What does it mean that the h_Fe was specified at 1V? Could someone give an example of when this h_Fe would apply \$\endgroup\$
    – Feynman137
    Apr 1, 2021 at 0:58
    \$\begingroup\$ For example an amplifier with the transistor biased around Vcc/2 rather than used as a switch (your application). \$\endgroup\$ Apr 1, 2021 at 2:21
