Assuming that I have the following circuit where I use a transistor as a switch:
Transistor as a switch
When the transistor is not active Vout will be equal to the Vcc and the current will become very high right? So if I want to add a combinatorial circuit or any other IC what should I do about that?
edit: The circuit that lead me to this question:
my circuit
S1 simulates what happens if the IR gate is blocked, and U1 is a quadruple NAND gate IC wired to form a NOT gate. I posted this question because XMM2 is measuring extremely high currents. Is that because the simulator is ignoring the saturation limit of the phototransistor?
  • \$\begingroup\$ In this circuit: When the transistor is not active Vout will be equal to the Vcc -that is true. the current will become very high -if you mean RLcurrent it is zero. The things changes if you connect something to Vout. \$\endgroup\$
    – user208862
    Apr 1, 2021 at 8:23
  • \$\begingroup\$ @MichalPodmanický I'm talking about the case where I have something connected to the output. \$\endgroup\$
    – curioso
    Apr 1, 2021 at 8:27
  • \$\begingroup\$ If you connect Led between Vout and 0V in this state, the Led will be ON and current thru Led will be I_led=(Vcc-3)/RL. Considering Vcc=5V and RL=1k the Led current will be 2mA. The voltage on Vout will be 3V now due to Led IV curve. \$\endgroup\$
    – user208862
    Apr 1, 2021 at 8:37
  • \$\begingroup\$ The whole transistor can be negleted in this state because of its CE resistance more than 1Mohm. \$\endgroup\$
    – user208862
    Apr 1, 2021 at 8:55
No, the current through the transistor and RLwill be zero. (Look at your switch equivalent. Where could the current flow to?)
Adding a second switch in parallel with the existing one will create OR logic. Switching on either one will power the load, RL. In the transistor circuit that means adding a second Rin and transistor.
  • \$\begingroup\$ "the current through the transistor and RL will be zero" That's what I thought at first but I simulated it on Multisim and it gave me a crazy high current so I got a little puzzled. Do you know why is that so? \$\endgroup\$
    – curioso
    Apr 1, 2021 at 8:25
  • \$\begingroup\$ Then the simulator is wrong:) \$\endgroup\$
    – Miss Mulan
    Apr 1, 2021 at 8:26
  • \$\begingroup\$ @MissMulan yeah probably, when the transistor is active it measures 500kA through the collector. \$\endgroup\$
    – curioso
    Apr 1, 2021 at 8:35
  • \$\begingroup\$ Post a cropped screengrab of your simulator setup. What value have you got for the supply voltage and RL? \$\endgroup\$
    – Transistor
    Apr 1, 2021 at 8:52
  • \$\begingroup\$ @Transistor I'll edit the question. 5V and 100kOhm \$\endgroup\$
    – curioso
    Apr 1, 2021 at 8:57
