I found the "collector light current" term in this datasheet (Vishay TEFT4300) but I can't find a definition for it on the internet nor figure out how it relates to the collector current.
I am particularly interested in this graph below: Collector Light Current vs. Collector Emitter Voltage
"I'm interested in estimating Ic based on the Irradiance I calculated (~0.5mW/cm^2)"
Ic mainly depends on:
  • How precise is the estimated value (mW/cm^2) or what is expected range
  • The value of the resistor connected to the collector (Rc)
  • The DC voltage source connected to the collector resistor (Vcc)
Assuming Vcc is given by your circuit, by increasing the Rc the operating point will move towards the origin (lower Ic and Vce), eventually leaving the active region and entering the saturation.
You could use the current for the active region on the graph as a lower estimate for saturation:
Example 1: Vcc = 5V, Ic (graph) = 130uA -> Rc = 38.4kOhm
This resistor would result in Vce = 0V (if that was possible), so you know the transistor left the active region and entered the saturation. The larger the resistor, the more you force it into saturation but the "dark current" would also limit this increase (since it would avoid the transistor turning off: Vce ~= Vcc).
Conversely, lower values will move the transistor into the active region, but this operating point would vary with temperature, for each different device you use and the real mW/cm^2.
Example 2: Vce = 2.5V (Vcc/2), Ic (graph) = 130uA -> Rc = 19.2kOhm
E.g., if the real mW/cm^2 is 1.0 instead of 0.5, the transistor saturates.
    \$\begingroup\$ Thank you for the thorough answer! \$\endgroup\$
    – curioso
    Commented Apr 1, 2021 at 12:51
7
Ica (what they are the "collector light current") is the current through the collector and out the emitter vs. Vce (collector to emitter voltage) at different intensity of light impinging on the device.
So, for example, if you had a Vce of 10V and shined a light of 0.1 mW/cm2 on it, you should expect an Ica of about 0.3 mA (more or less).
  • \$\begingroup\$ I think you meant 0.3mA right @jwh20? Could you further explain what you meant with "current through the collector and out the emitter"? Is it the same as Ic then? I'm interested in estimating Ic based on the Irradiance I calculated (~0.5mW/cm^2) \$\endgroup\$
    – curioso
    Commented Apr 1, 2021 at 10:27
    \$\begingroup\$ Yes, I did mean 0.3 mA. Since this is a two pin device, the collector current = emitter current. There is no other current here. \$\endgroup\$
    – jwh20
    Commented Apr 1, 2021 at 12:00
