I'm currently reading about the CMOS inverter from Rabaey Chandrakasan Nikolic - Digital Integrated Circuits 2nd Ed, it states: enter image description here
I'm okay with the first part, but I'm not sure if I totally understand what it does imply (starting from therefore), in conciseness:
1- How does a path existing with finite resistance between the output and supply or ground help with the low output impedance?
2- What does it mean for the inverter (a digital circuit) to have low output impedance? In analog circuits like the common-source/common-drain amplifier it meant that it can drive heavy loads (e.g. a large capacitance or at high frequency)
3- How does it help make it less sensitive to noise and disturbances?
I have one more question that I would be also happy if I get the answer to, the book also states that because the high and low output levels are equal to supply and ground voltage respectively, we know that it has a high noise margin, does knowing the fact about output voltage levels alone help us talk about the noise margin because I don't it feel that it says enough?
Thank you :)).
"What does it mean for the inverter (a digital circuit) to have low output impedance?"
Inverters has 2 output states:
  1. Vout ≅ VDD (logic 1)
or
  1. Vout ≅ GND (logic 0)
Hypothesis: Vout ≅ VDD
Attach a resistor R to Vout.
R will draw current out of Vout.
Low output impedance mean that you can lower R as much as you want (*) without Vout dropping.
(*) Within certain limits
Example:
Vout = 3 V
R = 30 Ohm
If the inverter has 0 Ohm output impedance, than it will be able to deliver 100 mA to the load R and Vout will remain at 3 V.
If the inverter has 10 Ohm output impedance, than it will able to deliver 75 mA to the load R but Vout will now drop to 3 * (3 / 4) = 2.25 Volt.
Output circuits stages are designed to show low output impedance in order to set/impose the output voltage to the load.
