I have designed a circuit using LT1013DID (SOIC 8 footprint) op-amp and while Spice simulation worked, I forgot about input common-mode voltage limit (which it seems is not simulated) and thus need an in/out rail to rail op-amp which LT1013DID isn't (it is out rail-to-rail only) as my real-life circuit/PCB does not work near power supply voltages.
LT1013DID has a specific footprint where pin 1 is A-IN and not A-OUT.
LT1013DID footprint
I am wondering if anyone is aware of any other op-amps with such footprint layout that I could use as a replacement?
So requirements are: 2 channel SOIC 8 in/out rail-to-rail op-amp with a single supply of more than ~17V that is pin-compatible with LT1013DID
  • \$\begingroup\$ The input voltage range can be as low as the negative (or 0 volt) rail so maybe consider lifting the positive rail by a couple of volts? \$\endgroup\$ – Andy aka Apr 2 at 9:46
  • \$\begingroup\$ Unfortunately, the PCB is already manufactured and I can't do changes to it. Therefore I am looking for an alternative if there is any (due to unfortunate choice of op-amp footprint). \$\endgroup\$ – Klemen Apr 2 at 9:57
  • \$\begingroup\$ What about a small solderable-to-the-existing-pads daughter board with a different chip. It's a pretty obscure layout for the LT1013. \$\endgroup\$ – Andy aka Apr 2 at 10:04
  • \$\begingroup\$ This will have to do in case no replacement is found, I am afraid. \$\endgroup\$ – Klemen Apr 2 at 10:16
  • \$\begingroup\$ I would start to go down that path and it needn't be bodgy or regarded as a bad solution. \$\endgroup\$ – Andy aka Apr 2 at 10:21
