A typical synchronous buck:
The normal switch node spike that people typically see when the high side FET turns on:
In the past i have been fairly negligible on this part. When the switch node spike occurs, Switch node voltage - VIN is always more than a typical body diode drop, so why doesn't the body diode of the high side FET conduct?
Thanks!
