I was playing around with some MCP3008 ADCs from Microchip with an Arduino. The playground has an example for the MCP3208 (which seems to be just a 12 bit version of the MCP3008)
Well, when I tried the example, I forgot to only read 10 bits instead of the examples 12 bits. I noticed the reading was from 0-4096
In the interest of learning, I tried doing 13 bits and could read to 8192. With 16 bits, to 65535.
Is this dangerous to do? As in, not accurate? I just had a cheap trimpot and breadboard. There was some noticeable bounce, 500 at 16 bit and about 90 at 13 bit. The drift was around 10 at 10 bit reading.
Are all ADCs typically the same chip that is just binned based on performance?
