I am pretty much a beginner in these parts, so can you help me?
Does the LM317 take ANY voltage and convert it into the adjusted one?
By "ANY" I mean that is in its voltage range, etc.
    \$\begingroup\$ Read the datasheet. I takes any voltage up to Vin MAX, and regulates well down to Vout + some dropout voltage (my guess is around Vout+2.5V?). Keep power dissipation and heat in mind. \$\endgroup\$ – Wesley Lee Apr 3 at 16:39
  • 5
    \$\begingroup\$ Welcome to EE.SE. The LM317 is fity years old and easy to use but it wastes the percentage of power that you don't need as heat. The higher the difference between the input and output voltage the more heat you generate and this can become a BIG PROBLEM. There are much better ways of regulating voltage. Why not edit your question to explain the actual problem you are trying to solve. \$\endgroup\$ – Transistor Apr 3 at 17:24
10
The 317's valid input voltage range is from a minimum of 3 V above its programmed output, to a maximum of 40 V (32 V for some types).
Within that range, it will provide approximately the programmed voltage on its output, as long as ...
  • its power dissipation is low enough for the heatsink you're using with it to keep its temperature within specification.
  • the output current being taken is within specification
  • you have input and output capacitors to keep it stable
Rapid variations in the input supply, like ripple on the reservoir capacitor after a rectifier, will be suppressed to some extent at the output. Ripple from low frequencies to 10 kHz will typically be reduced by at least 60dB (a factor of 1000) at the output. Above 10 kHz, the 317 runs out of gain and the suppression reduces.
Input ripple has another effect worth considering as well. Let's say you have 2 V peak to peak ripple on your input, say it's swinging between 9 V and 11 V as your rectifier-fed storage capacitors charge and discharge. Your DMM will read the average DC voltage of 10 V. That 3 V minimum voltage across the 317 needs to be maintained at all times, including the input troughs, so you can only safely supply 6 V output, not 7 V based on your meter reading.
  • \$\begingroup\$ And any AC component (changes in value) on the input voltage is not too fast. \$\endgroup\$ – WhatRoughBeast Apr 3 at 18:56
  • \$\begingroup\$ @WhatRoughBeast I did contemplate adding that, may yet do. \$\endgroup\$ – Neil_UK Apr 3 at 19:10
