I'm trying to output CAM data from EAGLE 6.2.0 to get some PCBs made at Advanced Circuits. Their preferred NC drill format (particularly the one used by their online FreeDFM tool) is
Excellon Format, ASCII Odd/ None, 2.4 Trailing Zero Suppression, English Units, No Step and Repeats.
Both their online tool and GC-Prevue are automatically recognizing my NC drill files as 2.3 format with leading zero suppression. So, while the holes are the correct size, they are strewn about an area 10x larger than the PCB, causing the DFM tool to go nuts and I'm about ready to follow.
Can I get EAGLE to give me 2.4 trailing-suppressed files (or maybe at least no suppression)? Or, is there a tool that can convert the mangled files EAGLE vomits out to something reasonable?
I've tried using the 'hack' described here in attempt to force no zero suppression, but then my files are detected as 3.3 precision.
My CAM job is defined as:
[Sec_8]
Name[en]="Drill File"
Prompt[en]=""
Device="EXCELLON"
Wheel=""
Rack=""
Scale=1
Output=".NC"
Flags="0 0 0 1 0 1 1"
Emulate="0"
Offset="0.0mil 0.0mil"
Sheet=1
Tolerance="0 0 0 0 0 0"
Pen="0.0mil 0"
Page="12000.0mil 8000.0mil"
Layers=" 44 45"
Colors=" 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 6 6 4 8 8 8 8 8 8 8 8 8 8 8 8 8 4 4 1 1 1 1 3 3 1 2 6 8 8 5 8 8 8 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 4 2 4 3 6 6 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0"
