I am using an A4988 Stepper Motor Driver, which is controlled with an STM32F767ZI on a Nucleo 144 board. The stepper motor takes 12 V with a maximum of 350 mA.
When powered, the motor simply flickers and stutters, but moves at a negligible speed.
Here is a circuit diagram of the setup, with voltage readings taking from a multimeter:
The potentiometer has been set correctly.
The same results occur even with two other A4988 drivers.
For reference, here is the code (though I don't believe this is a software issue):
main.c
#include "./headers/stm32f767xx.h"
#include <stdint.h>
int main(void)
    initMotor(0); // initialise the motor
    initLed(7); // initialise the led
    unsigned long a = 0;
    while (1)
        if (a == 50000)
            toggleLed(7); // this LED flashes a little quicker than twice per second
            stepMotor(0); // output a pulse to the driver to step the motor, attached to PA2
            a = 0;
        a++;
./drivers/led.c
#include "../headers/stm32f767xx.h"
void initLed(int pin)
    RCC->AHB1ENR |= RCC_AHB1ENR_GPIOBEN; // enable the GPIOB clock
    GPIOB->MODER |= (0x1 << (pin * 2)); // set to output
    GPIOB->OTYPER = 0x00; // push-pull mode
    GPIOB->ODR = 0x00; // set output register to 0 across all pins
void toggleLed(int pin)
    GPIOB->ODR ^= (0x1 << pin); // toggle the pin
./drivers/motor.c
void initMotor(int step_pin)
    RCC->AHB1ENR |= RCC_AHB1ENR_GPIOAEN; // enable the GPIOA clock
    GPIOA->MODER |= (0x1 << (step_pin * 2)); // set to output
    GPIOA->OTYPER = 0x00; // push-pull mode
    GPIOA->PUPDR |= (0x2 << (step_pin * 2)); // pull down the pin specified
    GPIOA->ODR = 0x00; // set output register to 0 across all pins
void stepMotor(int step_pin)
    GPIOA->ODR |= (1 << step_pin); // output to the pin specified
    GPIOA->ODR &= ~(1 << step_pin); // reset the output back to 0
With this code, I was expecting the motor to take steady and even steps, rather than the backwards-and-forwards stuttering it does.
I would appreciate any suggestions for the direction I should take from here, or any suggestions as to what the issue could be.
After some discussion, I updated my code a little to slow it down, here it is:
(only included the updated files)
main.c
#include <stdint.h>
int main(void)
    initMotor(0);
    initLed(0);
    uint32_t a = 0;
    while (1)
        if (a >= 150000)
            toggleLed(0);
            stepMotor(0);
            a = 0;
        a++;
./drivers/motor.c
    RCC->AHB1ENR |= RCC_AHB1ENR_GPIOGEN;
    GPIOG->MODER &= ~(0b11 << (step_pin * 2));
    GPIOG->MODER |= (0b01 << (step_pin * 2));
    GPIOG->OTYPER &= ~(0b1 << step_pin);
    GPIOG->PUPDR |= (0b10 << (step_pin * 2));
    GPIOG->ODR &= ~(0b1 << step_pin);
    GPIOG->ODR ^= (0b1 << step_pin);
    \$\begingroup\$ Do you have a datasheet for the stepper? The first thing to check would be that the phases of the stepper motor are correctly connected to the A4988 outputs. \$\endgroup\$
    – gcr
    Apr 5, 2021 at 2:36
    \$\begingroup\$ Are you sure 'stepMotor' function works to send a ~50% duty cycle PWM? \$\endgroup\$
    – Ernesto
    Apr 5, 2021 at 5:36
    \$\begingroup\$ @tlfong01 i have slowed it down, and the result is still the same \$\endgroup\$
    – Starman
    Apr 5, 2021 at 10:40
    \$\begingroup\$ @user15278978: Check how long your "step" pulse is. The A4988 requires a minimum of 1 microsecond, with some restrictions on rise and fall time. Get an oscilloscope, and see what your "step" pulse really looks like. \$\endgroup\$
    – JRE
    Apr 6, 2021 at 14:57
    \$\begingroup\$ @user15278978: All it takes is a pulse. One pulse = one step. The pulse has to meet the minimum requirements, though. \$\endgroup\$
    – JRE
    Apr 6, 2021 at 19:50
After many days, I have finally tracked down the causes of the issues.
  1. Software
I misunderstood the purpose of Pull Up/Pull Down resistors within the MCU. I thought floating pins (which the STEP pin on the A4988 driver is) had to be pulled up/down. However when changing the output of this pin, there is no need to use Pull Up/Pull Down resistors, simply setting the output is sufficient.
You can see the question and answer posted about my software here.
  1. Power source
Initially, I decided to use a 12V to 5V DC step down converter. This appeared to work at first (in the sense it was providing the correct voltage to the driver), but when I took readings of the voltage between the output pin on the Nucleo-144 and the GND pin on the driver, it gave fixed readings (there was no evidence of the output of the pin changing, despite the program running). Weirdly though, when taking a voltage reading between the GND pin on the Nucleo-144 board and the output pin instead, the voltage changed in the way it had been written to in the software. So, I connected up the 5V and GND pins on the Nucleo-144 to the driver power pins. When taking the reading between the GND pin on the driver and the output pin of the Nucleo-144, it was clear that this voltage issue had now been fixed.
  1. Setting the potentiometer
Having done a bit of searching around into motor stuttering, I came across this post on an arduino forum. In short, it mentions how the potentiometer being too high or too low can cause motor stuttering. I adjusted this, with the power running, until the motor was stepping nicely (without taking any backwards steps).
    \$\begingroup\$ Thank you for the feedback. Glad to hear you got it running, and even better that you explained how you got it going. +1 \$\endgroup\$
    – JRE
    Apr 9, 2021 at 14:20
-4
Question
MCU STM32 with stepper motor driver Allegro A4988 are moving a 2 coil, 4 wire, bipolar stepper motor ridiculously slowly, with flickers and stutters. How to fix?
a4988 pic 1
a4988 pic 3
a4988 pic 2
The OP's original code (See Appendix A, B, and C below)
Answer
Contents
1. The MCU + Driver _ Motor Schematic V0.1
2. The OP's STM32 C++ Test Code Analysis
1. The MCU + Driver + Motor Schematic v0.1
schematic 1
I skimmed the OP's three short functions and found them more or less OK, though I did not go step by step in detail to detect any bug.
I think I better test the A4899 driver and motor independently off line, without using any STM32 C++ code, but just use a NE555 timer to simulate the step pulses, and jumper wired by hand for inputting signals.
3. Offline (by hand without STM32 code) testing A4899 and motor, using an NE555 timer to simulate step pulses
3.1 Now I am read the A4988 datasheet, checking out the operation and timing requirement, to make sure the timing of the OP's code is OK.
(2) A4988: DMOS Microstepping Driver with Translator and Overcurrent Protection - Allegro
a4988 spec summary
4. Specification of the OP's Stepper Motor
op stepper motor summary
5. A4988 and Bipolar Step Motor Test Setup v0.2
5.1 WARNING: Do not connect or disconnect motor when A4988 power is on. Reason: motor coils are inductive devices. Back EMF when switch off coil current might fry A4988.
5.2 This basic test is for full step mode. Connect MS1, MS2, and MS3 to ground. Do not leave them floating, though datasheet says OK to do so.
a4988 test setup 1
  1. Troubleshooting Stepping Motor
    6.1 I have wired up the stepper motor for testing. I checked the resistance and found them around 3R. If I power them with 12V, current would be 4A, and when disconnecting, might create a back EMF of perhaps a couple of time of 12V or around 30V+. I think to play safe, I should monitor the coil current and start with only 6V.
stepper motor resistance
  1. I found my two stepping motors good. So I moved on to the driver, and found the answer for the OP's question here.
(13) My experiments with stepper motor - ScientistNobee, 2015mar12
References
(1) A3988: Quad DMOS Full Bridge PWM Motor Driver Datasheet - Allegro
(3) Using L293D Motor Driver to Control Bipolar Stepping Motor 28BYJ48 - Asked 1 year, 11 months ago Active 4 months ago Viewed 798 times
(4) Control of Stepping Motors A Tutorial - Douglas W. Jones, CS Dept, U Iowa 1995
(5) Stepping Motors Fundamentals AN907 - MicroChip 2004
(6) AliExpress A4988 Stepper Motor Driver Module, for Reprap with Heat Sink, 3D Printer Parts Accessory - US$0.6
(7) AliExpress Nema 17 stepper motor, 1 piece, 17HS2408, 4 wire, 42BYGH, 0.6a CE, CNC laser, 3D printer motor, cnc parts - US$10
(8) Stepper motor - NEMA-17 size - 200 steps/rev, 12V 350mA PRODUCT ID: 324 - AdaFruit US$14
(9) AdaFruit XY42STH34-0354A Stepper motor datasheet - AdaFruit
(10) TaoBao HY42DJ33 Stepper Motor
(11) Stepper Motors Tutorial - Appin Knowledge Solutions
(12) Stepper motor vibrating and not turning - Asked 8 months ago Active 7 months ago Viewed 315 times
/ to continue, ...
Appendices
Appendix A - The OP's Original Code - main.c
#include <stdint.h>
int main(void)
    while (1)
        if (a == 50000)
            a = 0;
        a++;
Appenidx B - The OP's Original Code - ./drivers/led.c
Appenidx C - The OP's Original Code - ./drivers/motor.c
Appendix D - Troubleshsooting the OP's A4899 Test Code v0.1
I skimmed the OP's three functions and found them in general more or less OK, although I did not go step by step to detect any bug. I think I better test the A4899 driver and motor independently off line, without using any STM32 C++ code, but just use a NE555 timer to simulate the step pulses, and jumper wired by hand for inputting signals.
1. Main Funtion
1.1 Initialize GPIO pins interfacing motor
1.2 Initialize the status LED pin
1.3 Repeatedly (a) Toggle LED pin, (b) Send one step pulse
# Appendix A - The OP's Original Code - main.c
#include <stdint.h>
int main(void)
    while (1)
        if (a == 50000)
            a = 0;
        a++;
# Appenidx C - The OP's Original Code - ./drivers/motor.c
Appendix D - A4899 Stepper Motor Driver Module
Description
This product is a breakout board for the Allegro A4988 DMOS Microstepping Driver with Translator and Over Current Protection.
This stepper motor driver allows you to operate bipolar stepper motors in full-, half-, quarter-, eight-, And sixteen-step modes, with an output drive capability of up to 35V and 2A.
The translator is the key to the easy implementation of the a4988.
It suffices to insert an impulse on the step input to operate the motor with a microstep.
There are no phase sequence tables, high frequency control lines, or complex interfaces to program.
The A4988 interface is ideal for applications where a complex microprocessor is unavailable or is overloaded.
Characteristics
Simple step and direction control interface
Five different step resolutions: full step, half step, quarter step, eight step and sixteen step
Adjustable current control allows you to adjust the maximum current output with a potentiometer,
That allows you to use voltages above the rated voltage of your stepper motor to achieve higher stepping rates
Intelligent chopping control that automatically selects the correct current decay mode (fast decay or slow decay)
Overheat thermal shutdown, undervoltage lockout and cross current protection
Protection against ground short circuits and short circuits
Warning
Connecting or disconnecting a stepper motor while the driver is powered can destroy the driver. More generally, rewiring something while it is being supplied with power causes problems.
Appendix E - HYU42DJ33 Steppeer Motor Spec
hy42dj33 spec
  • 8
    \$\begingroup\$ Again, this is not an answer - reposting the contents of the question with other screenshots and quotes from datasheets is in no way helpful. \$\endgroup\$
    – awjlogan
    Apr 6, 2021 at 8:52
  • 8
    \$\begingroup\$ Please, / no continue, ... \$\endgroup\$
    – Transistor
    Apr 6, 2021 at 10:12
  • 8
    \$\begingroup\$ @tlfong01: An answer based on the results of a practical test of the problem would be useful. A play by play description as you experiment is not so useful. 1. Do the experiment. 2. Determine the source of the problem. 3. Describe the cause of the problem and how to solve it in your answer. 4. Add a section at the end of your answer that (succinctly) describes how you found the cause and the solution. \$\endgroup\$
    – JRE
  • 6
    \$\begingroup\$ @tlfong01, this is not a high quality answer. I don't know if you're aware but there is a discussion on meta about how to handle a user who gives long, rambling, blog-style answers with a load of links and material just copied from other sites. I think you should read it. Try writing some direct answers with < 100 words. \$\endgroup\$
    – Transistor
    Apr 6, 2021 at 10:18
  • 8
    \$\begingroup\$ So what exactly is your answer? What is the reason and solution for the motor stuttering? Write that in a short paragraph instead of this load of copy/paste text. \$\endgroup\$
    – Sohail
    Apr 7, 2021 at 7:29
