This seems like a very common voltage. I remember older batteries used more round numbers like 1.5V or 3V or 9V.
3.7V seems very arbitrary but seems to be everywhere.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityThis seems like a very common voltage. I remember older batteries used more round numbers like 1.5V or 3V or 9V.
The voltage is dependent on the materials used in the cell chemistry and cannot be chosen per se.
3.7V is typical for Lithium chemistries. Similarly, 1.2V is typical for nickel-cadmium (NiCd), 1.2V for nickel-metal hydride (NiMh), 1.5V for alkaline batteries, and 2V for lead-acid.
Notice that 3V and 9V are multiples of 1.5V. 3V and 9V are not customized values simply because they are round figures. They have been chosen as such since they are batteries constructed from stacks of alkaline cells. The same is true for 6V and 12V lead-acid batteries made from stacks of 2V cells.
So, why are there so many lithium batteries today? They are rechargeable, have no memory, and have superior qualities with respect to energy, power density, power volume, and weight compared to the other forms of batteries mentioned above.
NOTE: Memory is a behavior that some battery chemistries display wherein their capacities decrease every time you recharge them if you are not properly maintaining them or discharging them to near-empty before recharging them. Think of it like letting the old gas at the bottom of your gas tank congeal and solidify and then filling it up again. You get less gas into and out of it every time.
To be slightly pedantic, the common AA, AAA, C and D "batteries" should really be called "Cells". The voltage of an individual cell is determined by its chemistry.
The common 9 Volt batteries are really batteries - a number of cells connected in series. The 9 volt battery is made of six 1.5 volt alkaline cells.
A nominal 12 volt car battery is made up of six 2.2 volt cells, and will be about 13.2 volts fully charged.
[5]
is a list and $1!$ is a factorial. Why can't a cell be a battery?
– wizzwizz4
Apr 6 at 17:41
Historically, the popular battery that owned the market was the "carbon-zinc" cell... in size AAA, AA, C, or D. Think garden variety Ray-O-Vac. These are 1.5V - that's decided by the chemicals in the battery, chosen for safety and low cost.
Appliances typically use them in series strings of 2, 3, 4, 6 or 8 cells - giving 3, 4.5, 6, 9 or 12 volts. The "9V" batteries have 6 tiny cells inside a package, and the "Lantern" batteries have 4 cells inside a package.
Since then, companies developed the "alkaline cell" chemistry - think Duracell/Energizer. The chemicals decide the voltage, so the chemistry had to be carefully chosen to a) be safe, b) be a similar 1.5V voltage, and c) be affordable. It provides much more energy in the same volume, and of course they used the same AAA, AA, C, D form-factors.
Note that carbon-zinc and alkaline are "primary batteries" meaning use once, and throw them away.
However, as economics changed, lithium battery technology has become popular. Those have a nominal voltage of 3.7 volts per cell. This was an all-out quest for maximum energy density: they were not willing to compromise to match up to an existing popular voltage such as 1.5V.
Lithiums are more expensive and are not used for everything. Many applications are a better fit for the less expensive and extremely low self-discharge rates of alkaline batteries, like TV remotes and smoke alarms.
Further, types like nickel-cadmium (1.2V) play well with the "solar garden light" application for a variety of reasons.
Power tool battery packs had largely settled on NiCd's big brother nickel-metal-hydride (also 1.2V)... however they are now migrating to lithium.
Lithium is not a "drop in" replacement like alkaline or NiMH. Lithium is very sensitive about charge and discharge management, and can catch fire if abused. As such, it requires special protective circuitry, and that must be accounted for either in the battery module itself, or in the charger circuit.
