I came across some products (fairly reputed) that use a series-parallel combination of LEDs and drive it directly using a CC source.
Here is the configuration of LEDs:
A series string consisting of 12 LEDs. 16 such strings in parallel. A total of 192 LEDs are laid out on a 30 cm X 30 cm metal core PCB. Thermals are good. After running for over an hour, the MCPCB back is roughly 60 degree C (140 degree F).
LED used - Samsung LM301H (Product page) (PDF datasheet here)
Vf of LED is roughly 2.7 V.
Sorting current - 65 mA but max current mentioned as 200 mA.
Power supply used is a meanwell 36 V 2500 mA CV-CC PSU (PDF datasheet here). I feel that this PSU runs in CC mode because PSU can deliver enough voltage (12*2.7 = 32.4 V). This design is relying on the wattage limit of meanwell driver so that driver hits the current limit and starts running into CC mode, in my opinion. When this happens, each LED will be getting 2500 mA / 16 = 156.25 mA (well under 200 mA limit).
LED datasheet mentions the bin voltage as a range with 0.1 V gap. (for ex: 2.7 to 2.8 V).
Is it okay to wire up such LEDs in the discussed series-parallel combination? Will the current distribution happen evenly in such case? (quite likely the string's collective Vf will be close to each other because of randomness but I want to understand how much Vf difference is acceptable for such designs to work reliably)
