I'm looking into the mathematical justification of how a capacitance multiplier works. Here is the circuit.
I have to prove that resulted grounded (multiplied) capacitance is (R2 * C)/R1 here by means of mathematics. It was checked in LTspice in that question:
Why does two-BJT transistor-based capacitance multiplier show bad performance
It turned out that a normal capacitor discharged over 0.22 sec whereas the equivalent of this circuit with R2 being 100k and R1 being 10 Ohms did so over 2200 sec
So I do nodal and loop analysis for this circuit.
Nodal analysis based on Kirchhoff's current law for Node1:
\$ C\frac{d(V_{a}-0V)}{dt} + \frac{V_{a}-V_{b}}{R_{2}} + 0A = 0 \$
\$ C\frac{dV_{a}}{dt} + \frac{V_{a}}{R_{2}} - \frac{V_{b}}{R_{2}} = 0 \$
Nodal analysis based on Kirchhoff's current law for Node2:
\$ V_{o} = V_{a} \$ (1)
This is because of op-amp "golden rules":
No current flows into the +/− inputs of the op amp. In a circuit with negative feedback, the output of the op amp will try to adjust its output so that the voltage difference between the + and − inputs is zero (V+ = V−).
Loop analysis for pictured loop based on Kirchhoff's voltage law:
\$ V_{b} - R_{1}I_{1} - R_{2}I_{2} = 0 \$ (2)
Voltage drop on R2:
\$ V_{b} - V_{a} = R_{2}I_{2} \$ (3)
\$ V_{b} - V_{a} - R_{2}I_{2} = 0 \$ (4)
\$ V_{b} - V_{o} - R_{2}I_{2} = 0 \$ (5)
From (2) and (4)
\$ V_{a} = R_{1}I_{1} \$ (6)
Voltage drop on R1:
\$ V_{b} - V_{o} = R_{1}I_{1} \$ (7)
From (1)
\$ V_{b} - V_{a} = R_{1}I_{1} \$ (8)
From (3) and (8)
\$ R_{2}I_{2} = R_{1}I_{1} \$ (9)
From (6) and (9)
\$ V_{a} = R_{2}I_{2} \$ (10)
From (4) and (9)
\$ V_{b} - V_{a} - R_{1}I_{1} = 0 \$ (11)
\$ V_{b} = V_{a} + R_{1}I_{1} \$ (12)
Getting back to capacitance:
\$ C\frac{dV_{a}}{dt} + \frac{V_{a}}{R_{2}} - \frac{V_{a} + R_{1}I_{1}}{R_{2}} = 0 \$
\$ C\frac{dV_{a}}{dt} = \frac{R_{1}I_{1}}{R_{2}} \$
\$ \frac{dV_{a}}{dt} = \frac{R_{1}I_{1}}{CR_{2}} \$
\$ I_{1} = \frac{q_{1}}{t} \$
\$ C = \frac{q_{2}}{V_{a}} \$
Now I'm stuck here.
What has to be done further? Regards.
