I'm trying to measure the battery voltage of 30V using the ADC of an AVR Atmega8, AVCC is connected to 5V.
I connected a suitable voltage divider: R1 is 270k, R2 is 10k. The result I get is wrong at all, at 30V I get 23V. The equation I use is batteryvoltage = 5*1023/adcReading.
// Read the AD conversion result
unsigned int read_adc(unsigned char adc_input)
ADMUX=adc_input|ADC_VREF_TYPE;
// Start the AD conversion
ADCSRA|=0x40;
// Wait for the AD conversion to complete
while ((ADCSRA & 0x10)==0);
ADCSRA|=0x10;
return ADCW;
unsigned int adcReading = 0;
adcReading = read_adc(0);
batteryVoltage = 5*1023/adcReading;
  • \$\begingroup\$ Why are you dividing by the adcReading? \$\endgroup\$ – pjc50 Jan 23 '13 at 10:24
  • \$\begingroup\$ @pjc50 to get the full reading of the battery ? \$\endgroup\$ – Mahmoud Jan 23 '13 at 10:25
  • \$\begingroup\$ adcReading should be numerator, not the denominator. Configured as it is, the result will decrease with increasing voltage. \$\endgroup\$ – Nick Johnson Jan 23 '13 at 10:29
  • \$\begingroup\$ @NickJohnson The result is always zero... How also can I modify it to bte the result increase with decreasing voltage? \$\endgroup\$ – Mahmoud Jan 23 '13 at 10:32
Your calculation for the battery voltage is wrong. Assuming adcReading varies from 0 to 1023, it should look like this:
batteryVoltage = (adcReading * 30) / 1023
Note though that denoting voltage like this, with integer volts, will only give you 31 possible readings (0 to 30). A more useful result might be in millivolts:
batteryVoltageMillivolts = (adcReading * 30000) / 1023
Note that in this case batteryVoltageMillivolts will have to be a long, not an int.
  • \$\begingroup\$ can you help me with the voltage divider issure please? I think its also affecting.. \$\endgroup\$ – Mahmoud Jan 23 '13 at 10:35
  • \$\begingroup\$ What voltage divider issue? You didn't specify one in the question. \$\endgroup\$ – Nick Johnson Jan 23 '13 at 10:37
  • \$\begingroup\$ I have specified R1 = 50k, R2=10k, this gives 5V at 30V, but still the output is wrong using your equations above. \$\endgroup\$ – Mahmoud Jan 23 '13 at 10:38
    \$\begingroup\$ You said R1=270k above! What's the actual reading at the adc input pin with a voltmeter? \$\endgroup\$ – pjc50 Jan 23 '13 at 10:40
  • \$\begingroup\$ You want to ensure that the divider allows some "overflow" - if you want to measure 32V but your ADC input voltage is 5V (ie max) at 30V you will have a problem! \$\endgroup\$ – Andrew Jan 23 '13 at 12:21
@Mahmoud - depending on the resolution of your ADC (10 bit, 12 bit?) I'd be minded to divide by 10 using your resistor divider - so 32V == 3.2V at the ADC
This gives a possible range of 50V == 5.0V at the ADC therefore no overloading of the input.
For the 10 bit ADC this then gives you a resolution of 0.049V for a 50V input
If you need a bit more accuracy, divide to 35V == 5.0V at the input which gives you a resolution of 0.034V
  • \$\begingroup\$ its 10bit of the AVR Atmega8 \$\endgroup\$ – Mahmoud Jan 24 '13 at 8:43
