I am making a circuit using a 4 pin hall sensor with arduino. It turns out that the hall sensor outputs a negative voltage as output, which arduino cannot read, so I will need a PNP transistor, I don't have one but I have a bunch of NPN (BC547) laying around. Is there any way I can make a PNP transistor or add circuitry to make the NPN into PNP? Thanks in advance. For more info about the hall sensor, the first pin is +ve second is Normally open third is Normally closed and fourth is -ve Schematic
Turns out that I have a pnp transistor with my Snap Circuits kit. I cracked it open, soldered some wires and now, it looks like this image Take a look at my Schematic above and tell if I need another resistor or somethin
