If we have an H-bridge made of 4 N-MOSFETs, the gate voltage applied to each pair must be different because in an active circuit the sources will have different voltages. How much?
    \$\begingroup\$ The difference will be approximately that of the value of the DC supply feeding the bridge. \$\endgroup\$ – Andy aka Apr 7 at 13:23
  • \$\begingroup\$ For large supply voltages, grossly exceeding typical \$V_{GS}\$ of MOSFETs, high-side driver ICs take care that the high-side MOSFET gates are driven with respect to the local Source Voltage \$\endgroup\$ – tobalt Apr 7 at 13:31
This assumes an on-off type H-bridge and not a linear H-bridge used in bridge tied audio amplifiers.
How much?
If you ignore protection features (required to limit gate-source voltages when the supply exceeds the maximum gate-source voltage), to efficiently drive current through the load requires these gate voltages to be present: -
And clearly, the difference in voltage between the two driven gates for the MOSFETs that are activated is just the supply voltage.
