Well, what is the FPGA with more Logic Elements per Dollar? I already tried to search some sites but the filters for the products do not include that option.
    \$\begingroup\$ LEs are a rather nebulous metric as not all are the same. There’s not too many fpga vendors, so it should be reasonably easy to do a price comparison. \$\endgroup\$
    – Kartman
    Commented Apr 8, 2021 at 13:30
  • \$\begingroup\$ What volume? For pricing is a major factor. \$\endgroup\$ Commented Apr 8, 2021 at 13:36
  • \$\begingroup\$ Generally, look at the larger members of relatively recent budget FPGA families from the biggest manufacturers (e.g. Spartan-x family). This is too close to a purchasing recommendation question for a more specific answer. \$\endgroup\$
    – user16324
    Commented Apr 8, 2021 at 14:29
This has been researched by UofT and Umass in the link below.
“ In between these extremes is a spectrum of logic block choices ranging from fine to coarse-grain logic blocks. FPGA architects over the last two decades have selected basic logic blocks made of transistors (noted above) [144], NAND gates [160], an interconnection of multiplexers [79], lookup tables [49], and PAL-style wide-input gates [217]. These choices were originally driven by intuitive insights on the part of architects, typically with very little data or analysis, with a few exceptions [79]. In this survey, we discuss how the research foundations for choosing a logic block were established, and then focus on the effect of logic block functionality on the three key metrics: area, speed, and power. In this discussion, we use silicon area as the proxy for cost, as is common. For a more detailed survey on the specifics of the logic blocks mentioned above, see [167] or [43].”
https://www.eecg.utoronto.ca/~jayar/pubs/kuon/foundtrend08.pdf
