Common mode means that both inputs "move" equally up or down.
To keep this simple, start out by imagining both inputs to be the exact same voltage (same source, even) and midway between the rails. In this case, both BJTs will share equally the current generated in \$R_\text{EM}\$. The split currents will generate their respective voltage drops across \$R_{\text{COL}_1}\$ and \$R_{\text{COL}_2}\$ and therefore the differential output between the two collectors will be \$0\:\text{V}\$.
Now, imagine that the two inputs (both moving identically, still) move slightly upward. When that happens, both emitters are also dragged upwards, too, and equally as much. This means more current is induced in \$R_\text{EM}\$. This current splits equally, again, between the two BJTs and, again, there is no difference in the output taken between the collectors. That's good.
But what change in current is incurred at each base? Well, each base will require a little more recombination current because the collector currents increased (by about half the current change in \$R_\text{EM}\$.) So it's pretty easy to see that the sources will "see" an impedance (the slightly changed voltage divided by the slightly changed base current.) Roughly speaking, and ignoring the Early Effect, this will be on the order of \$2\,\beta\,R_\text{EM}\$ for each input and is therefore considered "high impedance." (The differential impedance is, conversely, quite low. But that's another story.)
It's not quite so often that the common mode impedance is spoken of as more than "it's high," though. (These are usually driven by significantly lower impedance sources.) Instead, the CMRR is usually more important to know. In theory, this would be infinite as both collectors would move equally for any common mode change (assuming also that the resistors were ideal and exactly the same value, of course.) But the reality is that the BJTs themselves are never perfectly identical to each other and the resistors won't be perfectly matched, either. So there will always be some non-zero output difference to start out as well as some further change in that non-zero output difference when the inputs move identically together up or down. And that kind of thing is often more important to know about.
