I have a Dangerous Music Source. One of the momentary push buttons started to fail (I have to push it so hard to work that I'm afraid of breaking something else... I tried to re-solder it, but it seems to be an internal issue).
These buttons have an integrated LED (green in the case of my broken one). They have 4 pins to the circuit board, 2 rear ones for the contact, and 2 front ones for the led.
The space between the 2 front pins (LED) is 6mm.
The space between the 2 rear pins (contact) is 4.4mm.
The space between the row of 2 front pins and 2 rear pins is 5mm.
The width of the dark-gray plastic casing of the button is 7.5mm.
I am attaching 3 photos (downscaled to 1024 pixels wide) that show the button in details (I have removed the button cover and placed it on the board nearby).
photo 1 of switches
photo 2 of switches
photo 3 of switches
Due to the Stack Exchange 2MB limit on image file size, the full resolution images are on my website here: https://florianbador.com/pub/dangerous-music-source-broken-switch/
What are these switches? Where can I find them?
    \$\begingroup\$ What on earth is a dangerous music source? \$\endgroup\$
    – Hearth
    Apr 8, 2021 at 22:15
  • \$\begingroup\$ A manufacture would really help, are there any identifying marks? If not, Digikey has a parametric search, good luck: digikey.com/en/products/filter/pushbutton-switches/199 \$\endgroup\$
    – Mattman944
    Apr 8, 2021 at 23:03
  • \$\begingroup\$ It's just right-angle, through-hole mount tactile switches with integrated LED + a plastic cap. You don't actually need the LED though, it's just fluff. And you can toss on any switch there, the footprint should be somewhat standardized. \$\endgroup\$
    – Lundin
    Apr 9, 2021 at 6:40
I did an image search for "illuminated tactile switch"
It looks like the SPJ series by Shanpu:
https://www.shanpu.com.tw/en/product/tags/1/Tactile-Tact-switchees
More precisely the SPJP3******** based on the documentation.
  • \$\begingroup\$ Voltage isn't a spec for LEDs as it varies too much across the lot. Manufacturers specify the current and the circuit has to supply that one at maximum. \$\endgroup\$
    – Janka
    Apr 9, 2021 at 6:06
  • \$\begingroup\$ @FlorianB Be sceptical when they only list mechanical life or only electrical life. Usually means that the one not listed is subpar. \$\endgroup\$
    – Lundin
    Apr 9, 2021 at 6:44
  • \$\begingroup\$ I couldn't find any retailers, perhaps contact "dangerous" and ask them to supply the repair part? \$\endgroup\$ Apr 12, 2021 at 20:39
