I need to solder a tiny 3 mm by 5 mm SMD. Thankfully my school has a reflow oven that can do the actual soldering part, but I still need to accurately get the solder paste on there, so I was thinking of making a stencil.
We also have a laser cutting machine but it can't cut through metal and using other things like plastic results in the "threads" between the pads being so thin that they break. (BTW is there another material like Kapton film that could be cut super think and not break?)
Is there a way to manipulate a Gerber file so that a PCB machine will cut out holes straight through the area where the pads should be?
For example, using the picture for reference, create a Gerber file that tells the PCB machine to cut holes where the red pads are in the picture (not the red dots).
