I am trying to find a way to conditionally assign values to a signal in verilog similar to the with/select in VHDL. So far I found two ways https://www.chipverify.com/verilog/verilog-4to1-mux.
This is the first one:
module mux_4to1_assign ( input [3:0] a, // 4-bit input called a
input [3:0] b, // 4-bit input called b
input [3:0] c, // 4-bit input called c
input [3:0] d, // 4-bit input called d
input [1:0] sel, // input sel used to select between a,b,c,d
output [3:0] out); // 4-bit output based on input sel
// When sel[1] is 0, (sel[0]? b:a) is selected and when sel[1] is 1, (sel[0] ? d:c) is taken
// When sel[0] is 0, a is sent to output, else b and when sel[0] is 0, c is sent to output, else d
assign out = sel[1] ? (sel[0] ? d : c) : (sel[0] ? b : a);
endmodule
Second one:
module mux_4to1_case ( input [3:0] a, // 4-bit input called a
output reg [3:0] out); // 4-bit output based on input sel
// This always block gets executed whenever a/b/c/d/sel changes value
// When that happens, based on value in sel, output is assigned to either a/b/c/d
always @ (a or b or c or d or sel) begin
case (sel)
2'b00 : out <= a;
2'b01 : out <= b;
2'b10 : out <= c;
2'b11 : out <= d;
endcase
end
endmodule
Both examples were taken from the link I shared before, my QUESTION IS if there is something in Verilog, similar to VHDL using the with/select, that is easy to understand without using procedural blocks?.
The first verilog example does the job but it takes a bit to understand the logic. Please keep in mind I am not complaining about or criticizing any language, I just want to know how to improve code readability for this particular case.
